Serial LCD problem
Results 1 to 38 of 38
    Feb 2004
    Germany
    Mind,
    I have never used one of these displays,
    but a quick glance at the datasheet makes me feel the serial interface is I2C or SPI, not asynchronous.
    So it won't work using SEROUT.
    pressuming you have the controller configured and wired up correctly
    use SHIFTOUT or I2CWRITE.
    (Dependend on the controllers config)
    regards
    Ralph
    mind's Avatar
    mind Guest
    Hi
    Yes, it is meant to be an SPI interface. I had assumed SPI = serial, and therefore I should use SEROUT.
    I have made the changes, but still no luck
    Best regards
    Richard
    Feb 2004
    Germany
    Quote Originally Posted by mind
    Hi
    Best regards
    Richard
    Richard,
    could you post the changed code?
    regards
    Ralph
    mind's Avatar
    mind Guest
    Heya
    Here is the code at the moment, after changes:
        INCLUDE "modedefs.bas"
        DEFINE CHAR_PACING 1000
    @  DEVICE  PIC16F88, INTRC_OSC_CLKOUT, WDT_OFF, PWRT_ON, BOD_OFF, MCLR_OFF, PROTECT_OFF
        osccon = %01101110
        sspcon = %00110001
        trisb  = %00000000
        disable interrupt
        pause 500   ' wait for LCD to startup
        LCD_ChipSelect var portb.0
        LCD_CommandLow VAR portb.1
        LCD_SerialIn VAR portb.2
        LCD_Clock VAR portb.4
        SYMBOL mode = 5   ' tried mode 4 too
        HIGH LCD_ChipSelect
        LOW LCD_CommandLow
        shiftout LCD_SerialIn, LCD_Clock, mode, [$38]  ' function set
        pause 50
        shiftout LCD_SerialIn, LCD_Clock, mode, [$39]  ' function set
        pause 50
        shiftout LCD_SerialIn, LCD_Clock, mode, [$14]     ' bias
        pause 50
        shiftout LCD_SerialIn, LCD_Clock, mode,  [$78]     ' contrast set
        pause 50
        shiftout LCD_SerialIn, LCD_Clock, mode, [$5E]     ' contrast control
        pause 50
        shiftout LCD_SerialIn, LCD_Clock, mode,  [$6E]     ' follower control
        pause 200
        shiftout LCD_SerialIn, LCD_Clock, mode, [%00001111] ' display, cursor, blink all on
        pause 50
        shiftout LCD_SerialIn, LCD_Clock, mode, [$01]   ' clear display
        pause 50
        HIGH LCD_CommandLow
    loop:
        shiftout LCD_SerialIn, LCD_Clock, mode, ["Hello world"]
        Pause 500	' Wait .5 second
        Goto loop	' Do it forever
    Best regards
    Richard
    Feb 2004
    Germany
    Richard,
    I'm sorry I have to say this, but I'm not going to study the entire Datasheet for you.
    Here are some hints:
    - ChipSelect is active LOW, not HIGH
    - Data is sent MSB first with clock Idling HIGH --> Mode 5
    - Set OSCON according to your clock source and speed ($60 for 4MHz INTRC)
    Your schematic would also help to analyze the problem.
    regards
    Ralph
    Dec 2003
    Wichita KS
    Hello Richard,
    I still do not see a 13 being passed to your LCD in your code...
    Comment out all the wacky stuff....ALL of it....
    Send just the 13 and Hello world.
    I think you are bitin off more than you can chew all at once my friend.
    Make sure you have a pause 500 (1/2 second delay to make sure the LCD is turn on and "warmed up" (as I call it).
    A 1/2 second pause before you send the 13, and a 1/2 second pause after you send the 13... then send Hello world.
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    Feb 2004
    Germany
    Dwayne,
    thanks for trying to help,
    but at the moment there are other problems that "13"
    You can send as many "13's" as you want,
    if the Controller is never selected it will just do nothing!
    regards
    Ralph
    Dec 2003
    Wichita KS
    Hello Richard,
    You made a comment, that this is your first project...
    One projects as such, it is best to go the very BASICS of everything. Do not add bells and whistles *until* you get the crazy thing working. You said it was HD44780 compatible...
    Sending a Dec 13 will turn on the display and allow you to print ascii to it. This should be your main concern... NOT whether it blinks, does whistles, changes lines, smokes cigarettes for you, or drinks beer. 8-}
    AFter you get just those two things to work.. THEN experiement with one added command at a time....
    You are slowly eliminating variables... one at a time... instead of trying to elminate 15 variables... in which one of those 15 could be what you really need!
    Dwayne
    Ability to Fly:
    Feb 2004
    Germany
    DWAYNE,
    PLEASE...
    regards
    Ralph
    Dec 2003
    Wichita KS
    Hello Ralph,
    Gosh you ought to be proud of me remembering to "Quote" <chuckle>
    I agree with you... I sent another message... I just see so many "Variables" he is trying to play with...When he should only be concerned with one Variable...Turning it on. And possibly another... Writing "Hello" to it to verify that it is turned on.
    I have not used the Shiftout method... you did a splinded job on seeing that in the Data sheet. I can only assume he knows how to write to the controller... (how ever that is)... LIke you said before(which I agree)... I am not going to read the manual of a LCD that I don't care to use... But you and I both know what it takes to "tickle" that LCD to make it write ASCII...
    Dwayne
    Ability to Fly:
    mind's Avatar
    mind Guest
    Hi Ralph
    Thanks for the reply, and catching my inverted chip select level.
    I already had mode 5 in my code, and 4MHz as my clock speed (line 5), so yes, I have read the data sheets, but since I am a ME, rather than EE, there could be something that I am missing. I figured it would be obvious to someone with experience
    Best reagrds
    Richard
    Dec 2003
    Wichita KS
    Hello Mind,
    Mind>>Serial LCD is only a little more complicated
    Data, clock, Vdd, Vss, command select pin (command/data mode), chip select pin (so multiple chips can share the SPI interface).<<
    I have used both SERIAL, 4 bit and 8 bit buss LCD's. Complicated? I have designed my own Serial controlled LCD's, used on my Instrument panel of my Experiemental. <g>. Granted, there are many things I do not know. But I can only give you generic data on a controller that you said was compatible to the HD44780. How that data is fed to the LCD is up to the person who designed it.
    Ralph I see responded to you... He is top notch...Same with STeve, Melanie, Bruce, and Darrel. They work with it on a daily basis for their work.
    Mind>>So, yes, contrast is done in software. The manual says exactly what I quoted in my previous post about which bits to send to turn it on.
    And I wish I did have a scope... Time to schmoose some of my EE friends who do have scopes !<<
    That can help out a lot! It can get rid of the "Gotcha" and things that SHOULD be working... and you find out they are not working.
    Dwayne
    Ability to Fly:
  1. LCD problem with 16F628
    Last Post: - 19th September 2016, 09:28
  2. LCD serial backpacks
    By Archangel in forum Serial
    Last Post: - 30th December 2010, 05:51
  3. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 20:48
  4. Please help with EDE702 - Serial to LCD interface
    Last Post: - 30th October 2008, 03:48
  5. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
