Hi guys
I am posting this here, after going nuts trying to figure it out myself (repeatedly) and much googling with no luck.
I have a PIC16F88 and a 2 x 16 serial LCD using a ST7036 Sitronix controller. The controller is HD44780 compatible. The display remains blank (ie: nothing happens).
The code is as follows:
    INCLUDE "modedefs.bas"
    DEFINE CHAR_PACING 1000
@   DEVICE  PIC16F88, INTRC_OSC_CLKOUT, WDT_OFF, PWRT_ON, BOD_OFF, MCLR_OFF, PROTECT_OFF
    osccon = %01101110
    sspcon = %00110001
    trisb  = %00000000
    disable interrupt
    pause 500   ' wait for LCD to startup
    LCD_ChipSelect var portb.0
    LCD_CommandLow VAR portb.1
    LCD_SerialIn VAR portb.2
    LCD_Clock VAR portb.4
    Symbol LCDMode = N1200
    HIGH LCD_ChipSelect                          '  select LCD on SPI bus
    LOW LCD_CommandLow                       ' select command mode
    Serout LCD_SerialIn, LCDMode, [$38]     ' function set
    pause 50
    Serout LCD_SerialIn, LCDMode, [$39]     ' function set
    pause 50
    Serout LCD_SerialIn, LCDMode, [$14]     ' bias
    pause 50
    Serout LCD_SerialIn, LCDMode, [$78]     ' contrast set
    pause 50
    Serout LCD_SerialIn, LCDMode, [$5E]     ' contrast control
    pause 50
    Serout LCD_SerialIn, LCDMode, [$6E]     ' follower control
    pause 200
    Serout LCD_SerialIn, LCDMode, [$0C]     ' display on
    pause 50
    Serout LCD_SerialIn, LCDMode, [$01]     ' clear display
    pause 50
    Serout LCD_SerialIn, LCDMode, [$06]     ' entry mode right
    pause 50
    HIGH LCD_CommandLow   ' data mode
loop:
    Serout LCD_SerialIn, LCDMode, ["Hello world"]
    Pause 500	' Wait .5 second
    Goto loop	' Do it forever
So, since this is my first ever LCD project, I have probably made a bunch of assumptions which have gotten me into trouble. Any criticism or pointers would be much appreciated.
Best regards
Richard
