BCD conversion
Results 1 to 10 of 10
Thread: BCD conversion
    Feb 2004
    Germany
    Nick, here is a ready to run Code Snippet that does the conversion:
    InBuffer VAR BYTE[3]
    CounterA VAR BYTE
    ' Bits are shifted into an Array of Byte (InBuffer) here (LSB first)
    ' Place your Code to shift the bits in here...
     FOR CounterA = 0 TO 2
         'Revert the Bit order
         InBuffer[CounterA] = Inbuffer[CounterA] REV 8
         'Invert captured Data (if not required comment this line out)
         InBuffer[CounterA] = InBuffer[CounterA]^$FF
     NEXT CounterA
     'Output Raw Data to LCD (24 Bits, MSB first)
      LCDOUT BIN8 InBuffer[2],Bin8 InBuffer[1],Bin8 InBuffer[0]
    GOTO Main
    regards
    Ralph
    Macgman2000's Avatar
    Macgman2000 Guest
    Smile
    Thanks Ralph !!!! I will try it out this week.....geez, right now I have an urgent request for a speed controller FETs'n all ....hehehe.
    Best Regards,
    Nick
    Feb 2004
    Germany
    Hi Nick,
    RE: your PM
    I haven't found time yet to work on this project.
    It certailny is possible in PBP,
    a 70-90 kHz clock is not that fast, so a tight loop could do.
    Another option is to use the MSSP Module.
    I'll have a look into it when I find time.
    regards
    Ralph
  1. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 01:48
  2. A/D conversion problem in 18F2520, 2523, 2550 etc.
    By selimkara in forum mel PIC BASIC Pro
    Last Post: - 10th March 2008, 16:26
  3. Rotary BCD
    Last Post: - 15th October 2007, 03:04
  4. Strange A/D conversion...
    By Christos_K in forum mel PIC BASIC Pro
    Last Post: - 5th June 2005, 01:35
  5. HEX to BCD conversion
    Last Post: - 2nd February 2005, 14:39
