BCD conversion
Results 1 to 10 of 10
Thread: BCD conversion
    Macgman2000's Avatar
    Macgman2000 Guest
    Smile
    Hello All,
    I have the hardware set up using an LM393 (0v to -1.55v) to shift to standard TTL/CMOS. I am able to see the data by setting the calipers to 1" and analyzing the waveform to get 20480 (which is the resolution per inch) . It is being clocked out LSB to MSB. I have the PIC packing 3bytes but like I said it is backwards.
    I have most of the supporting readout code done and tested with dummy variables. The only thing holding me up is flipping the data around and scaling it (scaling factor already worked out). I will fiddle around with your suggestion.
    Thanks again!!!
    Best Regards,
    Nick
    Feb 2004
    Germany
    Nick, here is a ready to run Code Snippet that does the conversion:
    InBuffer VAR BYTE[3]
    CounterA VAR BYTE
    ' Bits are shifted into an Array of Byte (InBuffer) here (LSB first)
    ' Place your Code to shift the bits in here...
     FOR CounterA = 0 TO 2
         'Revert the Bit order
         InBuffer[CounterA] = Inbuffer[CounterA] REV 8
         'Invert captured Data (if not required comment this line out)
         InBuffer[CounterA] = InBuffer[CounterA]^$FF
     NEXT CounterA
     'Output Raw Data to LCD (24 Bits, MSB first)
      LCDOUT BIN8 InBuffer[2],Bin8 InBuffer[1],Bin8 InBuffer[0]
    GOTO Main
    regards
    Ralph
    Macgman2000 Guest
    Smile
    Thanks Ralph !!!! I will try it out this week.....geez, right now I have an urgent request for a speed controller FETs'n all ....hehehe.
    Best Regards,
    Nick
    Feb 2004
    Germany
    Hi Nick,
    RE: your PM
    I haven't found time yet to work on this project.
    It certailny is possible in PBP,
    a 70-90 kHz clock is not that fast, so a tight loop could do.
    Another option is to use the MSSP Module.
    I'll have a look into it when I find time.
    regards
    Ralph
  1. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 02:48
  2. A/D conversion problem in 18F2520, 2523, 2550 etc.
    By selimkara in forum mel PIC BASIC Pro
    Last Post: - 10th March 2008, 17:26
  3. Rotary BCD
    Last Post: - 15th October 2007, 04:04
  4. Strange A/D conversion...
    By Christos_K in forum mel PIC BASIC Pro
    Last Post: - 5th June 2005, 02:35
  5. HEX to BCD conversion
    Last Post: - 2nd February 2005, 15:39
