Reading if Pin is High or Low?
Results 1 to 30 of 30
Threaded View
  1. #28
    Well i this could be as easy as..
    MAIN:
        IF (UP = 0) AND (DOWN=1) THEN
           serout FM, T9600 ,["W01 01 200", CR, LF] 'Write velocity limit value
           serout FM,T9600,["P01 270000", CR, LF] 'Send MOVETO_ABSOLUTE command
        IF (DOWN = 0) AND (UP = 1) THEN
           serout FM,T9600,["P01 0", CR, LF] 'Send MOVETO_ABSOLUTE command
        if (DOWN = 1) AND (UP = 1) then ' <=== Switch is in central POS
           LOW Break_Pin
        goto MAIN
    Just connect a PIC i/o directly to the controller BREAK pin... this have to work... i guess.
    or if you feel to add extra parts...
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=392&stc=1">
    Both should work now!
  1. SERIN MIDI out of Synch?
    By jncortes in forum mel PIC BASIC Pro
    Last Post: - 9th June 2009, 21:08
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. Pic16f84 and RC5 kode
    By terminator in forum Bluetooth
    Last Post: - 18th June 2007, 22:40
  5. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 03:37
