Reading if Pin is High or Low?
Results 1 to 30 of 30
    Spindle's Avatar
    Spindle Guest
    Exclamation Reading if Pin is High or Low?
    Hey guys/gals.
    I am working on a project that involved an SPDT switch. I have the middle of the switch wired to a 5volt source and the other two wired to PORTB.5 and PORTB.7. What I want to do is check if PORTB.B or PORTB.7 goes high so then I can tell my PIC to drive my motor. PORTB.5 will be to drive my motor forward and PORTB.7 is to drive my motor reverse. Is there something similar to.
    if PORTB.5 = HIGH Then?
    Thanks in advanced.
    - Matthew
    Aug 2003
    yes, it's
    IF portb.5 = 1 THEN 'check if portb.5 is high
    Cheers, Art.
    1. Be sure you place a pull down resistor on both PORTB pins
    2. Be sure your pin is define as input with the TRIS setting too
    my 2 cents... as always
    TRISB.5=1
    IF PORTB.5 THEN ' do the same as IF PORTB.5=1 THEN
        ' do something here
    OR, if your PIC have some A/D built in, you can use one channel to read your switch and do all the according stuff on 1 pin. You just need few resistors.
    something like this...
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=385&stc=1">
    once it's done you use a snip of code like this
    ADCIN 0,ForwardReverse
    IF ForwardReverse<110 then
        Gosub MotorReverse
    IF ForwardReverse>140 then
        Gosub MotorForward
    110 and 140 are arbitrary value. Could work as is, but test it before. Set up a 8 bit A/D conversion.
    Spindle's Avatar
    Spindle Guest
    hrmm, something isn't right...
    [code]
    CMCON = 7 ' Disable analog comparator
    TRISA = %11110110 ' set PORTA to input
    TRISB = %11110000 ' set PORTB to output
    DEFINE HSER_BAUD 9600 'send serial data at 2400 baud
    UP VAR PORTB.5
    DOWN var PORTB.7
    FM VAR PORTB.2
    POSITION var word 'Position value
    VELOCITY var word 'Average velocity value
    FUNCTION var word 'Function register
    I var byte 'Loop variable
    TRISB.5 = 1
    TRISB.7 = 1
    MAIN:
    if UP THen
    serout FM, T9600 ,["W01 01 200", CR, LF] 'Write velocity limit value
    serout FM,T9600,["P01 270000", CR, LF] 'Send MOVETO_ABSOLUTE command
    for I = 1 to 100
    pause 25
    serout FM,T9600,["R01 00",CR,LF]
    serout FM,T9600,["R01 14",CR,LF]
    next
    if DOWN THEN
    serout FM,T9600,["P01 0", CR, LF] 'Send MOVETO_ABSOLUTE command
    for I = 1 to 100
    pause 25
    next
    goto MAIN
    [code/]
    I am trying to see which pin is high, RB7 or RB5 and then send the right command to the motor driving circuit. No movement however :\
    UP   VAR PORTB.5
    DOWN var PORTB.7
    FM   VAR PORTB.2
    T9600    con 2 ' <== Baudrate definition in case you don't use
                   ' INCLUDE "modedefs.bas" line
    MAIN:
        if UP THen
           for I = 1 to 100
               pause 25
               next
        if DOWN THEN
           for I = 1 to 100
               pause 25
               next
        goto MAIN
    The DEFINE HSER_BAUD 9600 'send serial data at 2400 baud have nothing to do with SEROUT, AND i don't see any crystal speed declaration. @9600 bauds with SEROUT, 8MHZ or higher is highely recommended.
    Spindle's Avatar
    Spindle Guest
    I am using a PIC16F628 if that helps. It still isn't working for some reason. When i flip the switch nothing happend, but then the motor starts turning in like 30-40 secs. Its weird hehe. Its also 3:40am and getting late. I'll look at it again with fresh eyes in the morning but any more help is still apreciated.
  1. SERIN MIDI out of Synch?
    By jncortes in forum mel PIC BASIC Pro
    Last Post: - 9th June 2009, 21:08
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. Pic16f84 and RC5 kode
    By terminator in forum Bluetooth
    Last Post: - 18th June 2007, 22:40
  5. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 03:37
