16F877 RAM Question
Results 1 to 9 of 9
    Aug 2003
    Default 16F877 RAM Question
    Hi Guys,
    I am currently working with a 16F877, and looking at the datasheet, it
    appears to have 336 total bytes of RAM. The issue I'm having is that my
    PBP program defines 71 bytes, and if I define and use a couple more bytes,
    my program goes totaly battly, leading me to beleive that I'm out of RAM.
    I understand that PBP uses RAM for library routines, and I am using a lot of
    library subroutines, but is this an expected number of bytes for a 16F877?
    Is there some special thing I need to do in order to use extra bytes on the
    chip, or must it be done in assembler?
    Cheers, Art.
    mmm, is it me or i think you mix 2 things here, codespace and RAM wich is far different.
    Where you get your 71 bytes results???
    Aug 2003
    I'm talking about RAM only.
    There are 4 banks that are supposed to contain 96, 80, 80 & 80
    bytes of RAM??
    Quote Originally Posted by Art
    well i should read your post better the first time. For subroutine, it will take much CodeSpace than RAM, except if you have ton's of variable definition.
    Personnally i never filled the whole RAM but... BUT hehe many times the CodeSpace.
    BUT, there's a but that i'm not sure of but someone will have the pleasure to set me straight if i'm wrong, PBP will probably manage the whole thing for you... i guess it will place the extra RAM blah blah in the CodeSpace section... pure guess here !
    PBP uses the same couple or three dozen variables over and again for it's routines. They are reused. Those variables aren't created again if you use the routine in several places. In an 16F877, with 370 bytes, you should have at least 330 bytes of RAM that you can assign for your own use. This all depends on your code, but you have to be doing some pretty drastic things, or have some huge arrays assigned to use up that much resource.
    Btw... PBP doesn't swap RAM into codespace. RAM is RAM, and codespace is codespace, the two aren't mixed unless YOU deliberately do it in your program.
    Aug 2003
    Hmm
    ADR var word : dat var byte : EEunit var byte		'define I²C address, data & unit variables
    delay var byte						'define delay time variable
    T1 var byte : T2 var byte : T3 var byte			'define real time buffers
    T4 var byte : T5 var byte : T6 var byte			'
    A1 var byte : A2 var byte : A3 var byte			'define alarm time variables
    A4 var byte : AA var bit  : AL var bit			'define alarm condition variable bits
    D1 var byte : D2 var byte : DB var byte			'define display digit buffers
    D3 var byte : D4 var byte				'
    D5 var byte : D6 var byte				'
    B0 var byte						'define GPS data bytes
    B2 var byte : B3 var byte				'
    B4 var byte : B5 var byte				'
    B6 var byte : B7 var byte				'
    DP var bit 						'define decimal point status bit
    JS var bit						'define joystick status variable
    DC var byte						'define display comparison variable
    RC var byte						'define real time clock comparison variable
    mode var byte						'define mode variable byte
    colcnt var byte						'define colon delay counter variable byte
    sndbuff var byte					'define sound buffer value variable byte
    soundcalc var byte : snd var byte			'define sound calc variable byte
    L0 var byte : L1 var byte : L2 var byte			'define variables for Lat & Longitudinal coordinates
    L3 var byte : L4 var byte : L5 var byte			'
    L6 var byte : L7 var byte : L8 var byte			'
    L9 var byte : LA var byte : LB var byte			'
    LC var byte : LD var byte : LE var byte			'
    LF var byte : LG var byte : N1 var byte			'
    LNG var byte : LAT var byte 				'
    last var DB.bit7 : first var DB.bit0			'define display buffer first & last bits for swapping
    msel var bit : ply var bit				'define mode display / play and pause status bits
    LTA var byte : LTD var byte				'define lookup table value & data bytes
    roll var byte : Rcnt var byte				'define display animation control variables
    roll1 var roll.bit0 : roll2 var roll.bit1		'
    roll3 var roll.bit2 : roll4 var roll.bit3		'
    roll5 var roll.bit4 : roll6 var roll.bit5		'
    rollo var byte						'
    rollo1 var rollo.bit0 : rollo2 var rollo.bit1		'
    rollo3 var rollo.bit2 : rollo4 var rollo.bit3		'
    rollo5 var rollo.bit4 : rollo6 var rollo.bit5		'
    rolls var byte						'
    rolls1 var rolls.bit0 : rolls2 var rolls.bit1		'
    rolls3 var rolls.bit2 : rolls4 var rolls.bit3		'
    rolls5 var rolls.bit4 : rolls6 var rolls.bit5		'
    F1 var byte : F2 var byte : F3 var byte			'
    F4 var byte : F5 var byte : F6 var byte			'
    SM var bit						'define search match status bit
    as you can see, there aren't a lot of variables.
    I think that the library variables are being added to total the 96 bytes
    in the first bank of RAM and then the compiler is clapping out there.
    If I add just a few more byte size variables and set them to any value
    to make sure they are used, my program will no longer start
    If I remember correctly from my 16F84 days, PBP uses some variables
    to pass values from the user's PBP routines to it's own library routines.
    with a bit of assembler hacking I have managed to claim some of these
    "middle man" variables in the past.
    Art.
  1. On-Chip RAM
    By DaveC3 in forum mel PIC BASIC Pro
    Last Post: - 28th July 2008, 11:16
  2. problem using 16f877
    By yrch in forum mel PIC BASIC Pro
    Last Post: - 20th February 2006, 19:58
  3. Timer Question 16f877
    By Bonxy in forum mel PIC BASIC Pro
    Last Post: - 8th November 2005, 09:40
  4. PIC 16F877 Question
    Last Post: - 5th August 2005, 19:06
  5. 18f452 tables in ram - code?
    By rshanks in forum mel PIC BASIC Pro
    Last Post: - 1st October 2004, 06:06
