Read the newbee threads, 16F877A no go.
Results 1 to 40 of 40
    BobbyA's Avatar
    BobbyA Guest
    Default Reply to Steve, serial output success.
    Hi Steve,
    You are a very bright fellow, and much more helpful than a bunch of dubious sample programs and not very clear books. At much more reasonable price too.
    Suppose I'm spoiled by how long the 8031 based parts and tools have had to refine their efforts. But it shouldn't be that hard to write an example of using a command, a list of what the allowable varibles are, and what each effects.
    To paraphrase, there are a lot of learning opportunities here.
    Best Regards,
    Bobby
    BobbyA's Avatar
    BobbyA Guest
    Default Not to overlook.
    I still stand by the comment that 8 variations of:
    Error c:\pbp\pbppic14.lib 2827 : [225] Undefined Symbol 'PAUSEUS'
    Is just a goofy error msg for having selected an illegal clock speed.
    Bobby
    I can agree. It should be something like illegal crystal speed definition but, once you know the problem source... it will never happen again. Well i guess.
    BobbyA's Avatar
    BobbyA Guest
    Talking Small wager
    Quote Originally Posted by mister_e
    Hi Steve,
    I'd be willing to make a small wager, perhaps a drink, that if another assembler were selected the same mistake would produce a different error.
    Call me a cynic but I'll go double or nothing that it's equally obsure...
    BR,
    Bobby
    you know, in ALL programming language, error message are often helpfull but often they wouldn't point you the exact line or part of code where the error is. It's amazing what a missplaced or missing ENDIF, WEND, Variable declaration could do also
    here's a reaally short example
    b1 var byte
    I2cread PORTB.0,PORTB.1,0,0,[b1]
    try this as is. Without anything else It compile O.K right ???
    Now remove the first line and compile the code and see what's happen
    ERROR Line 3: Expected '['. (a.bas)
    Feb 2004
    Germany
    Quote Originally Posted by BobbyA
    For sure, different systems produce different (nonsense) Error Messages.
    The best one I have ever seen was:
    A Nonexistent error has occured in Module xxxxx at Address yyyy
    (Guess what: It was Intel Hardware running a Microsoft OS . . .)
    regards
    Ralph
    BobbyA's Avatar
    BobbyA Guest
    Default Favorite errors.
    Hi Ralph, I sit corrected, it does say somewhere the "acceptable clocks speeds are". Although in my defense you didn't find it first time either.
    Steve, My favorite error occurs on a PC running MS too. If you remove the keyboard the error on POST is: Keyboard bad or missing, press F1 to continue.
    By the way adding the other configuration switches to the .inc file didn't resolve the need to press reset to get the program to run. Still learning.
    BR,
    Bobby
    > For the 16F877A, the datasheet calls out many configuration bit switches that are not addressed in the c:\pbp\16F877A.INC file, when using PM.
    Many? Name just one. Every item in the Configuration Word Address (Datasheet Register 14-1) is replicated in the PICBasic INC file. Try looking in \pbp\inc\M16f87XA.INC.
    If you correctly read the FAQ, I wrote...
    3.a. When using MeLabs default (PM) Assembler
    Open up the PBP directory, and in it you will find an INC subdirectory. Opening that up and you'll see a heap of files. Find the Mxxxx.INC file for the PIC you're interested in... (example M12F675.INC). If you can’t locate your exact PIC, it might be listed under a family of PICs that share the same settings (example chose M16F62X.INC if you need the settings for a 16F628).
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. Cleaning up code
    Last Post: - 2nd December 2009, 08:14
  3. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 12:20
  4. Q: using MCLR for Input on 12F683
    By picster in forum mel PIC BASIC Pro
    Last Post: - 31st January 2009, 16:25
  5. Changing declared variables names on the fly
    Last Post: - 16th December 2006, 07:34
