HSEROUT with 18F2420 won't work
Results 1 to 3 of 3
    SWITZERLAND (french speaking)
    Default HSEROUT with 18F2420 won't work
    I'm trying to use HSEROUT instead of SEROUT/SEROUT2 with my 18F2420.
    As the code below works with SEROUT2, I only get garbage characters while using HSEROUT.
    I use a 4MHz crystal, defines come from Mister E's calculator, settings are for 2400bps, ...
    What am I missing/doing wrong please?
    ' HSEROUT_18F2420.pbp
    @ __CONFIG _CONFIG1H, _OSC_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H ;_OSC_INTIO7_1H
    @ __CONFIG _CONFIG2L, _PWRT_ON_2L & _BOREN_OFF_2L & _BORV_0_2L
    @ __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_1_2H
    @ __CONFIG _CONFIG3H, _MCLRE_OFF_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_PORTBE_3H
    @ __CONFIG _CONFIG4L, _STVREN_OFF_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
    @ __CONFIG _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L
    @ __CONFIG _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
    @ __CONFIG _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L
    @ __CONFIG _CONFIG6H, _WRTB_OFF_6H & _WRTC_OFF_6H & _WRTD_OFF_6H
    @ __CONFIG _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L
    @ __CONFIG _CONFIG7H, _EBTRB_OFF_7H & _DEVID1 & _IDLOC0
    DEFINE HSER_SPBRG 160 ' 2400 Baud @ 4MHz, -0.08%
    SPBRGH = 1
    ' ====== PROGRAM ===================================================================================
    MAIN:
        HSEROUT ["Hello",13,10]
        'Serout2 PORTC.6,16780,["Hello",13,10] ' 2400bps DIN
        PAUSE 1000
        GOTO MAIN
    ' ====== CIRCUITRY =================================================================================
    'PORTA.0[02]
    'PORTA.1[03]
    'PORTA.2[04]
    'PORTA.3[05]
    'PORTA.4[06]
    'PORTA.5[07]
    'PORTA.6[10] OSC2 - Xtal
    'PORTA.7[09] OSC1 - Xtal
    'PORTB.0[21]
    'PORTB.1[22]
    'PORTB.2[23]
    'PORTB.3[24]
    'PORTB.4[25]
    'PORTB.5[26]
    'PORTB.6[27] ICSP
    'PORTB.7[28] ICSP
    'PORTC.0[11]
    'PORTC.1[12]
    'PORTC.2[13]
    'PORTC.3[14]
    'PORTC.4[15]
    'PORTC.5[16]
    'PORTC.6[17] TX
    'PORTC.7[18] RX
    'PORTE.3[01] MCLR
    Roger
    Default Re: HSEROUT with 18F2420 won't work
    Using 16780 as the MODE means that the data is being sent inverted. The USART on the other hand sends the data true (non inverted), that's the reason it doesn't work for you.
    Some chips can invert the UART output and it looks like you're in luck with the 18F2420, try adding BAUDCON.4=1 to your code.
    Thumbs up Re: HSEROUT with 18F2420 won't work
    There' only ONE word to say: Wow!!!
    Thanks a lot Henrik
    Roger
  1. Math problem that won't work
    Last Post: - 16th August 2012, 23:59
  2. Why LCD won't work with RS connected to PortA.6 of 18F452?
    Last Post: - 8th April 2012, 00:55
  3. My PIC program won't work! Plz Help?!
    By beckyzammi in forum mel PIC BASIC
    Last Post: - 4th March 2010, 18:26
  4. Replies: 3
    Last Post: - 28th October 2009, 05:18
  5. Basic Compiler won't work with Vista
    By AMay in forum mel PIC BASIC
    Last Post: - 7th June 2008, 10:04
