How to add two binary variables next to each other, without mathematical operations?
Results 1 to 5 of 5
    Default How to add two binary variables next to each other, without mathematical operations?
    The question is.
    Say I have variable A, which is 1110 in BIN. And have variable B, which is 1101 in BIN. I want to convert them to single variable, which will read as 11101101 in BIN, by just adding them next to each other. If I use "+", then binary values of these variables will be added, so mathematicaly, result will be correct, but this is not what I need.
    Default Re: How to add two binary variables next to each other, without mathematical operatio
    You need to shift the first variable "up" (to the left) 4 places and THEN add the second variable.
    Result = (VAR_A << 4) + VAR_B
    But yeah, it IS using a mathematical operator but why don't you want that?
    Because this binary variable is actually a pattern for dot matrix led display.
    Matrix is 10 pixels wide, 7 pixels in height. So say, I want to display two symbols on it, each are stored in separate variable, I have to place them next to each other
    I understand that you want to place the two nibbles next to each other within the byte but I don't understand why you want to do it without mathematical operation.
    Anyway, try the suggested method, it does what you're asking for.
    never mind, it just "lost in translation", your method will work, I believe
  1. Mathematical calculation
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 27th October 2013, 01:07
  2. how to get the mathematical function sin
    By minssss in forum mel PIC BASIC Pro
    Last Post: - 18th July 2010, 18:13
  3. Multiple operations at once?
    By sphinxifm in forum mel PIC BASIC Pro
    Last Post: - 16th June 2008, 08:53
  4. Mathematical problem
    By iugmoh in forum General
    Last Post: - 25th January 2008, 19:24
  5. Mathematical Precedence
    By keithdoxey in forum mel PIC BASIC Pro
    Last Post: - 6th October 2006, 22:44
