Pulse Input > Array > Output help
Results 1 to 4 of 4
    Aug 2005
    Default Pulse Input > Array > Output help
    Hi All
    Im just playing around with some code that im trying to use to look at incoming pulses, write them to an array and then output them with a specific delay (ie an offset in the array)
    Pulses are coming in from a PWM signal (which i want to delay to the output) at around 600hz
    my code on a 16f1847 roughly as follows:
    OSCCON = %01101010			' Oscillator internal 4 mhz PLL disabled
    CM1CON0.7 = 0				' Comparator 1 off
    CM2CON0.7 = 0				' Comparator 2 off
    CPSCON0.7 = 0				' Capsense module off
    MDCON = %00000000			' Disable the Modulator
    ANSELB = %00000000			' Select no analog
    TRISA=%00000000				' Port A all output
    TRISB=%00001001				' Port B all output except 3 ,1
    PulseArray var WORD [40]  ' 40 words, 640 bits total if we can run at 1khz this will allow delay of upto 640ms
    ArrayBit var word
    ArrayBit=0
    RunController:
    PulseArray.0[0] = PortB.0  'set the new 0 bit in the array as per b.0
    For ArrayBit = 1 to 639
    PulseArray.0[ArrayBit] = PulseArray.0[ArrayBit-1]     ' move them all over 1x
    Next ArrayBit	'Go do next count
    toggle portb.4 '    use p4 to check loop time on scope
    PortB.5 =   PulseArray.0[250]  ' output this bit ~ 250ms delay
    goto  RunController
    the problem im seeing is my loop time on p4 is around 3hz, whereas the loop time within the for..next loop is around 3khz
    so even if i up my clock speed to 20mhz it looks like its still not going to be fast enough to do this?
    Does anyone have any better solutions or advise?
    Default Re: Pulse Input > Array > Output help
    what you are looking for is a ring buffer.
    this will take ages and is unnecessary, just increment a pointer
    according to this thread you may need to review the parameters
    http://www.picbasic.co.uk/forum/show...ht=ring+buffer
    PulseArray var byte [32]  ' 256 bits total if we can run at 1khz this will allow delay of upto 256ms
    Arraytail var byte
    clear
    Arraytail=0
    RunController:
    PulseArray.0[Arraytail] = PortB.0  'set the last bit in the array as per b.0
    Arraytail= Arraytail+1
    latb.4 = !latb.4 '    use p4 to check loop time on scope
    latb.5 = PulseArray.0[Arraytail]  ' output this bit ~ 250ms delay
    pauseus 900  ;    adj to suit
    goto  RunController
    longer delay cascading arrays upto 700ms
    '*  Name    : delayline.BAS                                     *
    '*  Author  : richard                                           *
    '*  Notice  :                                                   *
    '*  Date    :                                                   *
    '*  Notes   : 16f1825                                           *
                 __config        _CONFIG1,    _FOSC_INTOSC & _CP_OFF & _WDTE_ON  &  _PWRTE_ON  &  _MCLRE_ON  & _CLKOUTEN_OFF
    OSCCON=$70
    DEFINE OSC 32   ' Oscillator internal
    ANSELA=0
    ANSELC=0   ' Select no analog
    TRISA=%111111
    TRISC=%001111
    PulseArray0 var byte [32]  ' 1023 bits total this will allow delay of upto 700ms
    PulseArray1 var byte [32]
    PulseArray2 var byte [32]
    PulseArray3 var byte [32]
    tail var byte
    head  var byte
    Arraytail var byte
    clear
    Arraytail=0
    RunController:
    tail = Arraytail
    head =  tail+1
    PulseArray0.0[tail] = Porta.5  'set the last bit in the array as per b.0
    PulseArray1.0[tail]= PulseArray0.0[head]
    PulseArray2.0[tail]= PulseArray1.0[head]
    PulseArray3.0[tail]= PulseArray2.0[head]
    Arraytail  =   head
    latc.4 = !latc.4 '    use p4 to check loop time on scope
    latc.5 = PulseArray3.0[head]  ' output this bit ~ 700ms delay
    pauseus 500  ;    adj to suit
    goto  RunController
    Aug 2005
    thanks for the replies and code richard
    After i saw your first reply, i messed around a little and came up with this
    PulseArray var byte[80]  ' 88 bytes 640 bits total
    ArrayTail var word
    GetThisPulse var word
    Difference var word
    Offset var word
    Arraytail=0
    GetThisPulse=0
    Offset = 250    '(250)
    '	----------  COLD START
    ' set all unused pins low
    Low PortA.0
    Low PortA.1
    Low PortA.2
    Low PortA.3
    Low PortA.4
    'Low PortB.0
    Low PortB.1
    Low PortB.2
    Low PortB.4
    Low PortB.5
    Low PortB.6
    Low PortB.7
    Pause 25
    clear
    Arraytail=0
    RunController:
    if arraytail >= 639 then arraytail = 0  ' circle
    if offset > arraytail then
        difference = offset-arraytail
        GetThisPulse = 639 - difference
        GetThisPulse = ArrayTail - offset
    latb.5 = PulseArray.0[GetThisPulse]  ' output this bit
    pauseus 300  ;    adj to suit
    goto  RunController
    it has compiled ok etc but I havent had time to scope it, but i think your second reply is a much cleaner and more practical solution
  1. Sharp pulse on ADC input and NAP
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 16th August 2011, 06:00
  2. How to reverse polarity on output pulse??
    Last Post: - 6th June 2009, 13:25
  3. Input Output interface
    By aratti in forum Schematics
    Last Post: - 5th November 2008, 21:36
  4. input output code
    By pitufo in forum mel PIC BASIC Pro
    Last Post: - 19th August 2008, 20:57
  5. Using 4 input to control 10 output
    Last Post: - 5th November 2004, 12:08
