Weak pullup on 18f2620
Results 1 to 3 of 3
    Jun 2016
    Default Weak pullup on 18f2620
    Each of the PORTB pins has a weak internal pull-up. A single control bit can turn on all the pull-ups. This is performed by clearing bit, RBPU (INTCON2<7>). The weak pull-up is automatically turned off when the port pin is configured as an output. The pull-ups are disabled on a Power-on Reset.
    The above is taken from the datasheet. Since I NEED to set portB.5 as an output and leave all the remaining 7 pins as input (trisB = %11011111). Can I use the weak pullup? Or it will disabled ?
    How should I read the above note: a single pin set as output will turn the weak pullup off?
    What does mean "The pull-ups are disabled on a Power-on Reset" ?
    Thank you for any clearification.
    Alberto
    Default Re: Weak pullup on 18f2620
    It means that INTCON2.7 is set by default (pullups disabled).
    When you clear the bit the pullups are enabled. But only for pins configured as inputs. If the PIC is reset the pullups are disabled.
    A single pin set to output disabled the pullup for that pin.
    At least that's how I read it.
    Jun 2016
    Thank you Henrik.
    Alberto
  1. Pullup confusion 12c508a
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 10th September 2016, 19:52
  2. neebee wants to know pullup or pulldown?
    By lecoind in forum mel PIC BASIC Pro
    Last Post: - 24th May 2009, 04:36
  3. pullup and pulldown resistor help
    By studysession in forum General
    Last Post: - 29th January 2009, 03:46
  4. switch on 1 weak pullup on portb?
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 5th December 2008, 19:32
  5. button pullup/down resistor?
    By davewanna in forum mel PIC BASIC Pro
    Last Post: - 19th June 2008, 06:13
