Programming RFM radio modules in Basic
Results 1 to 40 of 45
    Oct 2010
    Default Re: Programming RFM radio modules in Basic
    Now a small step, in the code is to add the DIO0 pin from RFM69HCW to PIC18F26K22.
    As i read from the net, that pin is the:
    Received data ready interrupt signal from RFM69HCW to microcontroller
    TRIS register must also be configured as input at that pin i guess as the RFM69HCW is the one sending data to PIC.
    That i believe will complete the connections between the PIC and the RFM.
    '*  Name    : 18F26K22.BAS                                            *
    '*  Author  : [Leonardo Bilalis]                                      *
    '*  Notice  : Copyright (c) 2018 [Leonardo Bilalis]                   *
    '*          : All Rights Reserved                                     *
    '*  Date    : 30/Jun/2018                                             *
    '*  Version : 1.0                                                     *
    '*  Notes   : This is a GPS Tracker based on the following components *
    '*          : PIC18F26K22 or PIC18F46K22 @ 64Mhz                      *
    '*          : MKT 3333 or 3339 GPS MODULE                             *
    '*          : 4D Systems ULCD Goldelox or Picasso Graphic Processor   *
    '*          : RFM69HCW the range will be approximatelly 1000 meters   *
      #CONFIG   ;
         CONFIG FOSC     = HSHP	        ; HS oscillator (high power > 16 MHz)
        CONFIG PLLCFG    = ON	        ;Oscillator multiplied by 4
        CONFIG PRICLKEN  = ON	        ;Primary clock enabled
        CONFIG FCMEN     = OFF	        ;Fail-Safe Clock Monitor disabled
        CONFIG IESO      = OFF	        ;Oscillator Switchover mode disabled
        CONFIG  BOREN    = SBORDIS      ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
        CONFIG  WDTEN    = ON           ; WDT is always enabled. SWDTEN bit has no effect                     ;|
        CONFIG  WDTPS    = 32768        ; 1:32768 ---> HERE enable the watchdog timer with a 1:32768 postscale;|
        CONFIG  PWRTEN   = ON
        CONFIG  HFOFST   = ON           ; HFINTOSC output and ready status are not delayed by the oscillator stable status
        CONFIG  MCLRE    = EXTMCLR      ; MCLR pin enabled, RE3 input pin disabled
        CONFIG  LVP      = OFF          ; Single-Supply ICSP disabled
        CONFIG  XINST    = OFF          ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
        CONFIG  DEBUG    = OFF          ; Disabled
        CONFIG  CP0 = OFF             ; Block 0 (000800-003FFFh) not code-protected
        CONFIG  CP1 = OFF             ; Block 1 (004000-007FFFh) not code-protected
        CONFIG  CP2 = OFF             ; Block 2 (008000-00BFFFh) not code-protected
        CONFIG  CP3 = OFF             ; Block 3 (00C000-00FFFFh) not code-protected
        CONFIG  CPB = OFF             ; Boot block (000000-0007FFh) not code-protected
        CONFIG  WRT0 = OFF            ; Block 0 (000800-003FFFh) not write-protected
        CONFIG  WRT1 = OFF            ; Block 1 (004000-007FFFh) not write-protected
        CONFIG  WRT2 = OFF            ; Block 2 (008000-00BFFFh) not write-protected
        CONFIG  WRT3 = OFF            ; Block 3 (00C000-00FFFFh) not write-protected
        CONFIG  WRTC = OFF            ; Configuration registers (300000-3000FFh) not write-protected
        CONFIG  WRTB = OFF            ; Boot Block (000000-0007FFh) not write-protected
        CONFIG  EBTR0 = OFF           ; Block 0 (000800-003FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR1 = OFF           ; Block 1 (004000-007FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR2 = OFF           ; Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR3 = OFF           ; Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks
        CONFIG  EBTRB = OFF           ; Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
    define  OSC 64
    OSCCON    = %01110000   ; 64Mhz
    OSCTUNE.6 = 1           ; Enable 4x PLL
    while ! osccon2.7 :WEND ; to make sure the pll has stabilised before you run any other code
    initialize:
    CLEAR
    TRISA = %11011111
    TRISC = %11010111
    SSPCON1 = %00100010 ' in here we se the 5th bit of the SSPCON1 register and the last 4 bits for the clock speed at 64Mhz.
    SSP1STAT = %11000000  ' in here i need a help to understand what bits must be configured
    CS1      VAR           LATA.5  ' chip select (SS) from PIC18F26K22 to RFM69HCW
    DIO0     VAR           PORTC.2 ' Received data ready interrupt signal from RFM69HCW to microcontroller
    SCK1     VAR           PORTC.3 ' clock from PIC18F26K22 to RFM69HCW
    SDI1     VAR           PORTC.4 ' data IN , MISO from PIC18F26K22 to RFM69HCW
    SDO1     VAR           PORTC.5 ' data OUT, MOSI from PIC18F26K22 to RFM69HCW
    SSPIF   VAR     PIR1.3          ' SPI interrupt flag
    SMP     VAR     SSP1STAT.7      ' Data input sample phase
    CKE     VAR     SSP1STAT.6      ' Clock Edge Select bit
    SSPEN   VAR     SSP1CON1.5      ' SSP Enable bit
    CKP     VAR     SSP1CON1.4      ' Clock Polarity Select
    CS1    = 1
    not really, in rx mode its PayloadReady in tx mode its PacketSent
    that's 1% of the job done
    cannot see any point to creating these vars , they will never be used
    Oct 2010
    That is what i meant
  1. basic pic programming
    By sshanmugapriya in forum mel PIC BASIC
    Last Post: - 25th February 2010, 06:02
  2. Car radio (Car radio and electronics support forum)
    By freewillover in forum Forum Requests
    Last Post: - 1st July 2009, 20:41
  3. Smart Radio RF620A and RF620RA modules
    By Colin612 in forum Serial
    Last Post: - 8th May 2008, 16:47
  4. LPRS/miniature radio modules
    By fowardbias in forum Off Topic
    Last Post: - 20th September 2005, 02:03
  5. Help With Easy Radio Modules
    By hughgoodbody in forum General
    Last Post: - 25th May 2005, 10:14
