Programming RFM radio modules in Basic
Results 1 to 40 of 45
    Default Re: Programming RFM radio modules in Basic
    imho the example schematic from hoperf data sheet has miso/mosi names transposed on the module so be wary.
    mosi is master out slave in and pic is the master
    Oct 2010
    yes i have noticed. I will use the trusted 18F26K22 you have suggested for my project last time.
    Is there any quick way to check whether the RFM module is powered up? Like to send a signal from the Master (PIC18F26K22) and at G0 of the modules port to connect and LED indicator. How may i know that the module is powered up?
    Oct 2010
    I did the simplest configuration connection between the PIC and the RFM69HCW.
    Both of the boards are exactly the same. One will be the TX and the other will be the RX.
    Still in a very early stage, and keep reading the SPI protocol.
    read a register on the module . write a new value to that register read the register again and confirm the new value
    looking at your picture there are two wires missing on each module , that's never going to work
    SPI is not RS232. Sure Richard spot it. You need to revise your connections.
    Also, your caps around the crystal, what values are?
    Oct 2010
    Hi Richard and Ioannis, sorry for the bad quality of the picture.
    Connections i believe are ok. But two wires werent visible on the first pic.
    Capacitors are 22p and crystal is at 16Mhz. This combination seems to work just fine on my previous circuits.
    on that subject why even use a crystal
    Connections i believe are ok. But two wires weren't visible on the first pic.
    wrong , did you even look at the schematic I provided ?
    there are 5 connections needed
    Oct 2010
    I'm confused about the SPI connection.
    In the manual of the PIC18F26K22 this is how do they have it Master and Slave.
    The MOSI from Master goes to MISO on slave and the MISO from master goes to MOSI on slave. Which it seems for me to be the right connection.
    But everywhere else on the NET i find it as following. MISO on Master goes to MISO on slave and MOSI on Master goes to MOSI on slave.
    https://www.google.gr/search?q=spi+c...w=1422&bih=701
  1. basic pic programming
    By sshanmugapriya in forum mel PIC BASIC
    Last Post: - 25th February 2010, 05:02
  2. Car radio (Car radio and electronics support forum)
    By freewillover in forum Forum Requests
    Last Post: - 1st July 2009, 19:41
  3. Smart Radio RF620A and RF620RA modules
    By Colin612 in forum Serial
    Last Post: - 8th May 2008, 15:47
  4. LPRS/miniature radio modules
    By fowardbias in forum Off Topic
    Last Post: - 20th September 2005, 01:03
  5. Help With Easy Radio Modules
    By hughgoodbody in forum General
    Last Post: - 25th May 2005, 09:14
