Programming RFM radio modules in Basic
Results 1 to 40 of 45
    Jan 2013
    Default Re: Programming RFM radio modules in Basic
    Hi Richard,
    Next I've got to squeeze your code into my Oshonsoft simulator, should be fun
    I have to choose a future proof PIC. Apart from having an spi bus, are there any other considerations to note? e,g, speed, memory etc.
    I already have modules with RFN22 on them, but I have some RFM69 and some RFM96 on order.
    Thanks very much, C.
    EDIT Hi again. I notice "Copyright (c) 2013 All Rights Reserved Can I have permission to post it on an Oshonsoft assistance forum, please?
    No problem , but I don't particularly want to support it [ there is a slight bug in the reset fifo sequence too ,should be $ca81 from memory I think]
    you realise of course that rfm69's are quite a different animal
    Jan 2013
    Hi Richard,
    I have been using: http://www.hobbyking.com/hobbyking/s..._Receiver.html for a couple of years. They are programmed using a Chrome APP and have RFM22 chips on them, so I can play with them, while I learn how to program later modules RFM69 and 96 for example.
    I hoped they would be similar, so once learnt, a different module could be programmed with few adjustments to the program.
    I now have 4 BASIC programs, gleaned from the net, that I can follow, and as you say it does look daunting. I have to convert one or more into Oshonsoft basic, for my system and skills.
    I've just got this one into Oshonsoft (compiles), but there are errors. So I commented out those bits with >>>>>>>>>>>>>>>>>>>> for correction later. I've enclosed it in case you see obvious mistakes (Clutching at straws!!)
    I realise your time is valuable.
    Regards, Eric.
    I found this useful , saves a lot of typing
    ps use word or wordpad to view
    Jan 2013
    Hi Richard,
    Thanks most useful.
    C.
  1. basic pic programming
    By sshanmugapriya in forum mel PIC BASIC
    Last Post: - 25th February 2010, 06:02
  2. Car radio (Car radio and electronics support forum)
    By freewillover in forum Forum Requests
    Last Post: - 1st July 2009, 20:41
  3. Smart Radio RF620A and RF620RA modules
    By Colin612 in forum Serial
    Last Post: - 8th May 2008, 16:47
  4. LPRS/miniature radio modules
    By fowardbias in forum Off Topic
    Last Post: - 20th September 2005, 02:03
  5. Help With Easy Radio Modules
    By hughgoodbody in forum General
    Last Post: - 25th May 2005, 10:14
