Programming RFM radio modules in Basic - Page 2
Page 2 of 2 FirstFirst 12
Results 41 to 45 of 45
  1. #41
    Default Re: Programming RFM radio modules in Basic
    Regarding the comments on the program, i leave them there for me. Sorry for disturbing your reading by using those comments. Because of i use them for my children project GPS, i try to keep those to remind me what i have done.
    there is a big difference between comments that impart some information and visual white noise that masks the very few bits of data that are crucially different
    and worthy of notation
    Oct 2010
    My knowledge and time not helping my self to quickly develop a simple LED to light from one end of RFM69hcw to the other.
    But i will keep reading and studding all the information needed to achieve my goal.
  3. #43
    Oct 2010
    Now a small step, in the code is to add the DIO0 pin from RFM69HCW to PIC18F26K22.
    As i read from the net, that pin is the:
    Received data ready interrupt signal from RFM69HCW to microcontroller
    TRIS register must also be configured as input at that pin i guess as the RFM69HCW is the one sending data to PIC.
    That i believe will complete the connections between the PIC and the RFM.
    '*  Name    : 18F26K22.BAS                                            *
    '*  Author  : [Leonardo Bilalis]                                      *
    '*  Notice  : Copyright (c) 2018 [Leonardo Bilalis]                   *
    '*          : All Rights Reserved                                     *
    '*  Date    : 30/Jun/2018                                             *
    '*  Version : 1.0                                                     *
    '*  Notes   : This is a GPS Tracker based on the following components *
    '*          : PIC18F26K22 or PIC18F46K22 @ 64Mhz                      *
    '*          : MKT 3333 or 3339 GPS MODULE                             *
    '*          : 4D Systems ULCD Goldelox or Picasso Graphic Processor   *
    '*          : RFM69HCW the range will be approximatelly 1000 meters   *
      #CONFIG   ;
         CONFIG FOSC     = HSHP	        ; HS oscillator (high power > 16 MHz)
        CONFIG PLLCFG    = ON	        ;Oscillator multiplied by 4
        CONFIG PRICLKEN  = ON	        ;Primary clock enabled
        CONFIG FCMEN     = OFF	        ;Fail-Safe Clock Monitor disabled
        CONFIG IESO      = OFF	        ;Oscillator Switchover mode disabled
        CONFIG  BOREN    = SBORDIS      ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
        CONFIG  WDTEN    = ON           ; WDT is always enabled. SWDTEN bit has no effect                     ;|
        CONFIG  WDTPS    = 32768        ; 1:32768 ---> HERE enable the watchdog timer with a 1:32768 postscale;|
        CONFIG  PWRTEN   = ON
        CONFIG  HFOFST   = ON           ; HFINTOSC output and ready status are not delayed by the oscillator stable status
        CONFIG  MCLRE    = EXTMCLR      ; MCLR pin enabled, RE3 input pin disabled
        CONFIG  LVP      = OFF          ; Single-Supply ICSP disabled
        CONFIG  XINST    = OFF          ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
        CONFIG  DEBUG    = OFF          ; Disabled
        CONFIG  CP0 = OFF             ; Block 0 (000800-003FFFh) not code-protected
        CONFIG  CP1 = OFF             ; Block 1 (004000-007FFFh) not code-protected
        CONFIG  CP2 = OFF             ; Block 2 (008000-00BFFFh) not code-protected
        CONFIG  CP3 = OFF             ; Block 3 (00C000-00FFFFh) not code-protected
        CONFIG  CPB = OFF             ; Boot block (000000-0007FFh) not code-protected
        CONFIG  WRT0 = OFF            ; Block 0 (000800-003FFFh) not write-protected
        CONFIG  WRT1 = OFF            ; Block 1 (004000-007FFFh) not write-protected
        CONFIG  WRT2 = OFF            ; Block 2 (008000-00BFFFh) not write-protected
        CONFIG  WRT3 = OFF            ; Block 3 (00C000-00FFFFh) not write-protected
        CONFIG  WRTC = OFF            ; Configuration registers (300000-3000FFh) not write-protected
        CONFIG  WRTB = OFF            ; Boot Block (000000-0007FFh) not write-protected
        CONFIG  EBTR0 = OFF           ; Block 0 (000800-003FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR1 = OFF           ; Block 1 (004000-007FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR2 = OFF           ; Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR3 = OFF           ; Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks
        CONFIG  EBTRB = OFF           ; Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
    define  OSC 64
    OSCCON    = %01110000   ; 64Mhz
    OSCTUNE.6 = 1           ; Enable 4x PLL
    while ! osccon2.7 :WEND ; to make sure the pll has stabilised before you run any other code
    initialize:
    CLEAR
    TRISA = %11011111
    TRISC = %11010111
    SSPCON1 = %00100010 ' in here we se the 5th bit of the SSPCON1 register and the last 4 bits for the clock speed at 64Mhz.
    SSP1STAT = %11000000  ' in here i need a help to understand what bits must be configured
    CS1      VAR           LATA.5  ' chip select (SS) from PIC18F26K22 to RFM69HCW
    DIO0     VAR           PORTC.2 ' Received data ready interrupt signal from RFM69HCW to microcontroller
    SCK1     VAR           PORTC.3 ' clock from PIC18F26K22 to RFM69HCW
    SDI1     VAR           PORTC.4 ' data IN , MISO from PIC18F26K22 to RFM69HCW
    SDO1     VAR           PORTC.5 ' data OUT, MOSI from PIC18F26K22 to RFM69HCW
    SSPIF   VAR     PIR1.3          ' SPI interrupt flag
    SMP     VAR     SSP1STAT.7      ' Data input sample phase
    CKE     VAR     SSP1STAT.6      ' Clock Edge Select bit
    SSPEN   VAR     SSP1CON1.5      ' SSP Enable bit
    CKP     VAR     SSP1CON1.4      ' Clock Polarity Select
    CS1    = 1
  4. #44
    not really, in rx mode its PayloadReady in tx mode its PacketSent
    that's 1% of the job done
    cannot see any point to creating these vars , they will never be used
    Oct 2010
    That is what i meant
  1. basic pic programming
    By sshanmugapriya in forum mel PIC BASIC
    Last Post: - 25th February 2010, 06:02
  2. Car radio (Car radio and electronics support forum)
    By freewillover in forum Forum Requests
    Last Post: - 1st July 2009, 20:41
  3. Smart Radio RF620A and RF620RA modules
    By Colin612 in forum Serial
    Last Post: - 8th May 2008, 16:47
  4. LPRS/miniature radio modules
    By fowardbias in forum Off Topic
    Last Post: - 20th September 2005, 02:03
  5. Help With Easy Radio Modules
    By hughgoodbody in forum General
    Last Post: - 25th May 2005, 10:14
