Sequence of statements makes code work differently. (PIC16F628A)
Results 1 to 11 of 11
    Bombay, India
    Default Re: Sequence of statements makes code work differently. (PIC16F628A)
    Without seeing your schematic, my guess would be the Read-Modify-Write issue documented in the data sheet. Try to write to PORTA as a whole rather than in bits to confirm this is the issue.
    Resistor-led-pin, that's all
    Strange, and how to write PORTA in whole? like this?
    PORTA=%00000001
    It does not work, even setting PORTA.1=1 does nothing
    Try
    SIKO:
    PORTA=%00000011
    PAUSE 500
    PORTA=%00000000
    PAUSE 500
    GOTO SIKO
    Everybody together now:
    Remember to disable analog functions...
    628A has analog functions?
    P.S. I do have CMCON disabled...
    Oct 2009
    Page 1 of the data sheet !
    2 analogue comparitors - Pins PORTA.0 to PORTA.3
  1. Darrels interrupts and multiple SOUND statements, will it work?
    Last Post: - 26th January 2015, 08:42
  2. Replies: 13
    Last Post: - 10th July 2012, 19:05
  3. LED chaser - Scanner Sequence PIC16F628A
    By izzyblackout in forum Code Examples
    Last Post: - 3rd February 2011, 15:09
  4. Why doesn't this servo code work?
    By artswan in forum mel PIC BASIC Pro
    Last Post: - 5th December 2009, 23:18
  5. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
