Sequence of statements makes code work differently. (PIC16F628A)
Results 1 to 11 of 11
    Default Sequence of statements makes code work differently. (PIC16F628A)
    Hello,
    below is the super simple code
    SIKO:
    HIGH PORTA.0
    HIGH PORTA.1
    PAUSE 500
    LOW PORTA.0
    LOW PORTA.1
    PAUSE 500
    GOTO SIKO
    There are leds connected to porta.1 and porta.0
    The above code works, but only first line
    If I place at first line code for PORTA.0 it works, but next line, for PORTA.1 does not works. If I swap them, then PORTA.1 will work, but PORTA.0 - not. But if I modify code a bit, to look like this, then it works properly.
    SIKO:
    HIGH PORTA.0
    PAUSE 500
    LOW PORTA.0
    HIGH PORTA.1
    PAUSE 500
    LOW PORTA.1
    GOTO SIKO
    [/code]
    Why this happens?
    I have no TRISA, etc defined, as manual told us, HIGH/LOW statement in PBP does all necessary, so this is why it is so slow, but it appears not to work?
    Bombay, India
    Default Re: Sequence of statements makes code work differently. (PIC16F628A)
    Without seeing your schematic, my guess would be the Read-Modify-Write issue documented in the data sheet. Try to write to PORTA as a whole rather than in bits to confirm this is the issue.
    Resistor-led-pin, that's all
    Strange, and how to write PORTA in whole? like this?
    PORTA=%00000001
    It does not work, even setting PORTA.1=1 does nothing
    Try
    SIKO:
    PORTA=%00000011
    PAUSE 500
    PORTA=%00000000
    PAUSE 500
    GOTO SIKO
    Everybody together now:
    Remember to disable analog functions...
    628A has analog functions?
    P.S. I do have CMCON disabled...
    Oct 2009
    Page 1 of the data sheet !
    2 analogue comparitors - Pins PORTA.0 to PORTA.3
    Yes it does, the comparators are analog and enabled by default.
    Your code doesn't show that. What does having CMCON disabled mean? What are you writing to it?
    From the datasheet
    The PORTA pins are multiplexed with comparator and
    voltage reference functions. The operation of these
    pins are selected by control bits in the CMCON
    (Comparator Control register) register and the VRCON
    (Voltage Reference Control register) register. When
    selected as a comparator input, these pins will read
    as ‘0’s.
    When you do stuff like
    PortA.0 = 1
    PortA.1 = 1
    All bit operations on a register is performed as a read-modify-write operation. The port is read, modified and written back - it's the way it works inside the PIC itself. If the read operation returns a state of a pin that is different to what you set then that erroneous state will be written back to the port and you get "weird" and "unexpected" results. Having analog functions enabled is THE most (un)popular cause of this happening.
    Having too much load, or a capacartive load on the actual output is another cause. In this case the voltage level at the pin isn't allowed to rise to a level where the read operation of the second command actually "gets" a logic 1.
    If you Google read modify write you'll find loads and loads of explainations.
    Aug 2003
    Simple trick to shadow the port with a latch byte and send that to the port at the expense of some speed.
    portalatch var byte
    portalatch = 0’
    portalatch.bit0 = 1
    PORTA = portalatch'
    Even though it would have been pins left analogue this time, it will still cause hard to debug problems.
  1. Darrels interrupts and multiple SOUND statements, will it work?
    Last Post: - 26th January 2015, 08:42
  2. Replies: 13
    Last Post: - 10th July 2012, 19:05
  3. LED chaser - Scanner Sequence PIC16F628A
    By izzyblackout in forum Code Examples
    Last Post: - 3rd February 2011, 15:09
  4. Why doesn't this servo code work?
    By artswan in forum mel PIC BASIC Pro
    Last Post: - 5th December 2009, 23:18
  5. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
