HEDS5540 optical encoder
Results 1 to 24 of 24
    Default Re: HEDS5540 optical encoder
    you could look at nbit math or use a pic18 and long vars
    you can glean a bit more precision breaking the calc up a bit
    where 43200 counts would give 4709.2
    frac = enc_counter.lowbyte * 1090
    posn1  = div32 100          ;mm*100          ;mv 2790
    posn2 = (enc_counter.highbyte&15) * 2791  ; mm*100   mv 41865
    frac = (enc_counter.highbyte>>4) * 44657
    posn3 =  div32 100                       ;mm     mv6698
    posn3=  posn3 + (posn1+posn2)/100       ;mm
    frac=   ((posn1+posn2)//100 +5)/10        ;round it up
    serout2 PORTa.0,84, [13,10,#enc_counter,9,dec posn3,".",#frac       ]
    Hello Richard, thank you again for help. Your code works and take a little improvement. I make some changes, first got a smaller precision wheel dia. 25mm (circ. 78,53975mm) and divide the encoder reading /2. Now the encoder reading is only 720 per one rev.
    The code is as follows:
    Main_Loop:
    enc_counter = enc_counter /2
    if Flag = 1 then
    posn2 = (enc_counter.highbyte&15) * 2794  ; mm*100
    frac = (enc_counter.highbyte>>4) * 44680
    frac=   ((posn1+posn2)//100 +10)/10        ;round it up
    Lcdout $fe, 1
    lcdout  "Dist: ",dec posn3,".",#frac
    Flag = 0
    goto Main_Loop
    Now I can measure up to 7100mm, but still more or less precise.
    Next step will be order one of the PIC18x mcu and try long variables.
    Here are suitable to use the same encoder reading code (written in ASM) and simple change the word var to long var?
    I think its not that easy. When I have the 18x PIC I think, I will need more help with this project. Thanks.
    is incorrect , it will round the number up always
    is the way to round the number up if the last digit is 5 or more
    using n-bit math
    result
    ready v3
    turns 23 f 489
    33609 3664.3145
    turns 23 f 486
    33606 3663.9875
    turns 23 f 484
    33604 3663.7694
     Include "N-Bit_MATH.pbp"
    enc_new VAR BYTE   bank0
    enc_old VAR BYTE   bank0
    enc_counter VAR WORD   bank0
    Flag var BYTE        bank0
    tmp         var  byte[4]
    res         var  byte[4]
    tmp1        var  byte[4]
    posn        var WORD
    turns       var word
    frac        var WORD
    ; Set variable value @ startup
    Flag = 1                   ;preset a value    for testing
    enc_new = 0
    enc_old= 0
    enc_counter = 33609      ;preset a value    for testing
    Main_Loop:
    if Flag = 1 then
    turns=  enc_counter /1440
    frac=   enc_counter //1440
    serout2 PORTa.0,84, [13,10,"turns ",#turns,9,"f ",#frac ]
    if frac then
    @  MOVE?CP 157000, _tmp
    @  MOVE?WP _frac, _tmp1
    @  MATH_MUL  _tmp1, _tmp, _res
    @  MOVE?CP 1440000, _tmp
    @  MATH_DIV  _res, _tmp, _tmp1
    @  MOVE?PW _tmp1, _posn
    @  MOVE?CP 144, _tmp
    @  MATH_DIV  REG_Z, _tmp, _tmp1
    @  MOVE?PW _tmp1, _frac
    posn=posn+turns*157
    serout2 PORTa.0,84, [13,10,#enc_counter,9,dec4 posn,".",dec4 frac       ]
    Flag = 0
    goto Main_Loop
    I try to compile your code. I downloaded the N-Bit_MATH.pbp include, but the compiler stops with this error message:
    "Bad data type"
    If I try to compile only the N-Bit_MATH.pbp (only for test) and its do not compile. Stops on first line:
    REG_X VAR BYTE[PRECISION] BANK0 SYSTEM
    with the same error message MCU is the same 16F628A, For test I try also 16F688 with the same result. Something I'am doing wrong, I think.
    You need to define the constant PRECISION and assign it a value equal to the number of bytes to use for the values in the math routine. And you need to do this before including N-Bit. In this case it looks like Richard opted for 32bit values (4 bytes)
    PRECISION CON 4 SYSTEM    '32bit values
    Include "N-Bit_Math.pbp"
    If you open the N-Bit file you'll find a link to the thread on this forum: http://www.picbasic.co.uk/forum/showthread.php?t=12433
    Yes, right. I forgot this line. After putting this line as you say the code compiles OK. Now I do some testing and trying to understand the code.
  1. 2 Beam Optical Pulse Generator
    By WOZZY-2010 in forum Schematics
    Last Post: - 6th April 2010, 05:03
  2. USB Optical mouse as motor encoder
    By RodSTAR in forum mel PIC BASIC Pro
    Last Post: - 24th August 2008, 16:09
  3. optical voice link
    Last Post: - 18th May 2008, 22:11
  4. Using a optical coder
    By debutpic in forum mel PIC BASIC Pro
    Last Post: - 16th October 2007, 05:57
  5. Using the optical sensor from a ball mouse
    By lsteele in forum General
    Last Post: - 5th September 2007, 17:45
