HEDS5540 optical encoder
Results 1 to 24 of 24
    Default Re: HEDS5540 optical encoder
    For testing and learning the 16F628A is seems to be OK. But now I try to convert the pulse reading to distance. One full encoder turn generates 1440 pulses. The wheel diameter is 25mm, the circumference is 157mm. I want reading precision to 0,1mm. I try basic math like:
    Main_Loop:
    if Flag = 1 then
    let counter = (enc_counter/36) * 157 / 4
    Lcdout $fe, 1
    lcdout  Dec counter     ; display counter value on LCD
    Flag = 0
    goto Main_Loop
    But the precision is terrible, can you explain me the right way?
    157/1440 = .109 mm per encoder tick
    .109 * 256 * 10 = 279
    distance * 10 = (counts * 279)/256
    to use pbp's higest resolution integer functions
    counter = enc_counter */ 279
    lcdout  Dec counter/10 ,".", dec counter//10     ; display counter value on LCD
    problem here is that when enc_counter > 60000 [or thereabouts] the internal 32bit result will overflow and the result will be wrong
    you could look at nbit math
    ps you could also use div32
    counter = enc_counter * 1000
    counter =  div32 917
    Thank You Richard for helping me. That's great, now the "core" of my distance meter works perfectly. Yes, the max. distance what I can measure is near six and a half meter which is enough for me. If I want to measure more than 6,5m simply zeroed the reading and start count from that point. Now I must implement negative reading when I go to opposite direction from zero the reading must be from -1..... to -655,3.
    Your explanation helping me a lot, once again Thank You.
    I finally assembled my distance meter based on rotary optical encoder and precision wheel. But still I have problem with math and precision.
    For example, wheel circumference is 157mm, and when I take a 30 revs the result must be 4710mm, but the MCU calculates only 4708,1mm which is 1,9mm difference. Is there a way to improve the precision?
    I use Richard's math:
    The precision 0,1mm is enough for me, the max. measurable distance want be 6000mm. I try some change, if I improve the precision to 0.01mm then the max. measurable distance shortened to 600mm and this not enough.
    you could look at nbit math or use a pic18 and long vars
    you can glean a bit more precision breaking the calc up a bit
    where 43200 counts would give 4709.2
    frac = enc_counter.lowbyte * 1090
    posn1  = div32 100          ;mm*100          ;mv 2790
    posn2 = (enc_counter.highbyte&15) * 2791  ; mm*100   mv 41865
    frac = (enc_counter.highbyte>>4) * 44657
    posn3 =  div32 100                       ;mm     mv6698
    posn3=  posn3 + (posn1+posn2)/100       ;mm
    frac=   ((posn1+posn2)//100 +5)/10        ;round it up
    serout2 PORTa.0,84, [13,10,#enc_counter,9,dec posn3,".",#frac       ]
    Hello Richard, thank you again for help. Your code works and take a little improvement. I make some changes, first got a smaller precision wheel dia. 25mm (circ. 78,53975mm) and divide the encoder reading /2. Now the encoder reading is only 720 per one rev.
    The code is as follows:
    Main_Loop:
    enc_counter = enc_counter /2
    if Flag = 1 then
    posn2 = (enc_counter.highbyte&15) * 2794  ; mm*100
    frac = (enc_counter.highbyte>>4) * 44680
    frac=   ((posn1+posn2)//100 +10)/10        ;round it up
    Lcdout $fe, 1
    lcdout  "Dist: ",dec posn3,".",#frac
    Flag = 0
    goto Main_Loop
    Now I can measure up to 7100mm, but still more or less precise.
    Next step will be order one of the PIC18x mcu and try long variables.
    Here are suitable to use the same encoder reading code (written in ASM) and simple change the word var to long var?
    I think its not that easy. When I have the 18x PIC I think, I will need more help with this project. Thanks.
    is incorrect , it will round the number up always
    is the way to round the number up if the last digit is 5 or more
  1. 2 Beam Optical Pulse Generator
    By WOZZY-2010 in forum Schematics
    Last Post: - 6th April 2010, 04:03
  2. USB Optical mouse as motor encoder
    By RodSTAR in forum mel PIC BASIC Pro
    Last Post: - 24th August 2008, 15:09
  3. optical voice link
    Last Post: - 18th May 2008, 21:11
  4. Using a optical coder
    By debutpic in forum mel PIC BASIC Pro
    Last Post: - 16th October 2007, 04:57
  5. Using the optical sensor from a ball mouse
    By lsteele in forum General
    Last Post: - 5th September 2007, 16:45
