Use any pin as tmr input?
Results 1 to 2 of 2
    Feb 2004
    Michigan, USA
    Default Use any pin as tmr input?
    Is there a way to use any pin as an input to the timers? I need to add a feature to a currently in production design that reads 2 frequencies but the CCP1 and CCP2 pins are currently used for other things.
    The device is 18F2550 @ 20mhz.
    Default Re: Use any pin as tmr input?
    For that you need a device with PPS, Peripheral Pin Select, the 18F2550 doesn't have that.
    Perhaps the 18F27J53 can work in its place (it's just the first one I found so make sure to look around).
  1. Zener on input pin OK ?
    By luminas in forum mel PIC BASIC Pro
    Last Post: - 17th October 2011, 20:55
  2. Maixium voltage on a input pin
    By Rob Martin in forum mel PIC BASIC Pro
    Last Post: - 21st April 2008, 10:57
  3. Mclr As Input Pin?
    By omid_juve in forum mel PIC BASIC Pro
    Last Post: - 24th December 2007, 06:33
  4. Input pin help
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2007, 09:35
  5. Input / output using same pin
    By leonel in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 21:19
