Re: How to make an LED gradually and slowly get brighter and dimmer?
The first problem is that I'm using a 16F886 and I can't seem to get this code to work with it. I've done some reconfiguring, and PBP will compile it for the 16F886, but I get an error message when I actually try to program the chip, so I'm clearly not doing something correctly.
firstly there is not much point reposting my code , you need to post what you are using , my example is for a pic16f1825
for a 16f886 things will be different
osc is different, ccp1 and 2 pins are different , ansel settings are different, config word is different tris ..........
Also, I really don't fully understand what is going on. I understand what the code is doing, but I don't understand the CCP module well enough to understand what setpwm is doing. Although the line "while pl" doesn't make any sense to me. Doesn't there need to be some sort of statement like "while pl < 99"?
in nearly all computer languages false=0 anything else is true
so "while pl" means while pl is true ie anything but 0
CCPR1L = PW>>2;
ccp1con=12|((PW&3)<<4); led2
CCPR2L = Pl2>>2; led1
ccp2con=12|((Pl2&3)<<4);
10 bit pwm is high 8 bits =CPRxL , LOW 2 bits = CCPxCON bits 4,5
so our 10 bit pwm value "PW" is deconstructed CCPR1L = PW>>2 moves high 8 bits into CCPR1L
and with [ccp1con=12|((PW&3)<<4)] the low two bits "PW&3" are shifted to bit 4,5 posn and or(ed) into ccp1con
