Strange behavior on PORTB on a PIC18F26K20
Results 1 to 8 of 8
    Default Re: Strange behavior on PORTB on a PIC18F26K20
    looks like the classic read modify write issue
    check out this video for an explaination [View streaming media version: link]
    http://www.microchip.com/webinars.mi...cName=en556253
    It looks like you're missing the % in front of all numbers that are to be interpreted as binary by the compiler (or is that just the forum engine dropping that character (again)?)
    Apr 2011
    Kent, UK
    Try this. Use LAT instead of PORT for outputs. Inputs must use PORT!
    Tim.
    '*  Name    : 18F26K20test.PBP                                  *
    '*  Author  : *************                                     *
    '*  Notice  : Copyright (c) 2016 *************                  *
    '*  Date    : 7/31/2016                                         *
    '*  Notes   : PIC18F26K20 - Test                                *
    #MSG "Compiling code for " + __PROCESSOR__
    ' Device fuses configuration - PIC18F26K20
        CONFIG  FOSC = HS             ; HS oscillator
        CONFIG  PWRT = OFF            ; PWRT disabled
        CONFIG  BOREN = SBORDIS       ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
        CONFIG  BORV = 18             ; VBOR set to 1.8 V nominal
        CONFIG  WDTEN = ON            ; WDT is always enabled. SWDTEN bit has no effect
        CONFIG  WDTPS = 512           ; 1:512
        CONFIG  CCP2MX = PORTC        ; CCP2 input/output is multiplexed with RC1
        CONFIG  PBADEN = OFF          ; PORTB<4:0> pins are configured as digital I/O on Reset
        CONFIG  LPT1OSC = OFF         ; Timer1 configured for higher power operation
        CONFIG  HFOFST = ON           ; HFINTOSC starts clocking the CPU without waiting for the oscillator to stablize.
        CONFIG  MCLRE = ON            ; MCLR pin enabled; RE3 input pin disabled
        CONFIG  STVREN = ON           ; Stack full/underflow will cause Reset
        CONFIG  DEBUG = OFF           ; Background debugger disabled, RB6 and RB7 configured as general purpose I/O pins
        CONFIG  CP0 = OFF             ; Block 0 (000800-003FFFh) not code-protected
        CONFIG  CP1 = OFF             ; Block 1 (004000-007FFFh) not code-protected
        CONFIG  CP2 = OFF             ; Block 2 (008000-00BFFFh) not code-protected
        CONFIG  CP3 = OFF             ; Block 3 (00C000-00FFFFh) not code-protected
        CONFIG  CPB = OFF             ; Boot block (000000-0007FFh) not code-protected
        CONFIG  WRT0 = OFF            ; Block 0 (000800-003FFFh) not write-protected
        CONFIG  WRT1 = OFF            ; Block 1 (004000-007FFFh) not write-protected
        CONFIG  WRT2 = OFF            ; Block 2 (008000-00BFFFh) not write-protected
        CONFIG  WRT3 = OFF            ; Block 3 (00C000h-00FFFFh) not write-protected
        CONFIG  WRTC = OFF            ; Configuration registers (300000-3000FFh) not write-protected
        CONFIG  WRTB = OFF            ; Boot Block (000000-0007FFh) not write-protected
        CONFIG  EBTR0 = OFF           ; Block 0 (000800-003FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR1 = OFF           ; Block 1 (004000-007FFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR2 = OFF           ; Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks
        CONFIG  EBTR3 = OFF           ; Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks
        CONFIG  EBTRB = OFF           ; Boot Block (000000-0007FFh) not protected from table reads executed in other blocks
    define OSC  20   ' Using 20Mhz oscillator - remember to change fuse to HS
    INCLUDE "bs2defs.bas"
    restart:
    TRISA     =    %011111  ' Set 0-4 pins on PortA to inputs, 5-7 pins to outputs
    TRISB     =    %000000  ' Set all pins on PortB to outputs
    TRISC   =   %000000  ' Set all pins on PortC to outputs
    ANSEL  = %000000  ' Make AN0 - AN7 Digital (pins RA0, RA1, RA2, RA3, RA5 on PIC18F26K20)
    ANSELH = %000000  ' Make AN8 - AN15 Digital (pins RB2, RB3, RB1, RB4, RB0 on PIC18F26K20)
    ' Set all pins low to reset any pins that went high due to device connection
    LATA = 0                   ' Set all pins on PORTA low
    LATB = 0                   ' Set all pins on PORTB low
    LATC = 0
    ' Port alias setup
    led1 var LATB.0
    led2 VAR LATB.1
    led3 VAR LATB.2
    led4 VAR LATB.3
    lcd  var LATB.4      ' Serial output to LCD
    btnr var PORTA.0      ' Right arrow button
    btns vAR PORTA.1      ' Select button
    btnu var PORTA.2      ' Up arrow button
    btnl var PORTA.3      ' Left arrow button
    btnd var PORTA.4      ' Down arrow button
    ' Variable declaration
    start:
    SerOut lcd,N9600,[254,1] ' Clear LCD screen
    Pause 1
    goto ledanims
    mainloop:
    ' For now, as a test of the buttons, just send a test string to the LCD
    ' After this is proven, send different texts (bluetooth, PIC to PIC, wordlength, etc.)
    if btnr = 1 then btnrgt
    if btns = 1 then btnsel
    if btnu = 1 then btnup
    if btnl = 1 then btnlft
    if btnd = 1 then btndwn
    goto mainloop
    btnrgt:
    Pause 1
    serout lcd,N9600,["Right button"]
    goto start
    btnsel:
    Pause 1
    serout lcd,N9600,["Select button"]
    goto start
    btnup:
    Pause 1
    serout lcd,N9600,["Up button"]
    goto start
    btnlft:
    Pause 1
    serout lcd,N9600,["Left button"]
    goto start
    btndwn:
    Pause 1
    serout lcd,N9600,["Down button"]
    goto start
    ledanims:
    'high PORTB.0
    'PORTB.0 = 1
    led1 = 1
    led1 = 0
    'led1 = 0                        ' <--- If I add this back in, this pin works correctly
    'PORTB.0 = 0
    'low PORTB.0                  ' <--- This statement does the job by itself
    'high PORTB.1
    'PORTB.1 = 1
    led2 = 1
    'led2 = 0
    led2 = 0
    'PORTB.1 = 0
    'PORTB.1 = 0
    'low PORTB.1
    'high PORTB.2
    'PORTB.2 = 1
    led3 = 1
    led3 = 0
    'PORTB.2 = 0
    'low PORTB.2
    'high PORTB.3
    'PORTB.3 = 1
    led4 = 1
    led4 = 0
    'PORTB.3 = 0
    'low PORTB.3
    goto ledanims
    there is some bad advise here
    lcd var LATB.4 ' Serial output to LCD ;THIS IS WRONG
    start:
    Pause 1
    use of LATx ports in "highlevel" commands is incorrect and will not work as expected
    lcd var PORTB.4 ' Serial output to LCD , IS CORRECT
    And there are still digits missing where binary representation is used to set the registers, which can be quite confusing.
    Sep 2016
    If you're referring to the sets of 0's and 1's which would be immediately following the percentage sign, as a bank of 8 bits, there are 8 digits in the original code. I hadn't noticed that they got truncated to 6 digits in the paste... very interesting. Anyway yeah, that's another forum/paste glitch.
    Dos
    TRISA     =    %00011111  ' Set 0-4 pins on PortA to inputs, 5-7 pins to outputs
    TRISB     =    %00000000  ' Set all pins on PortB to outputs
    TRISC   =   %00000000  ' Set all pins on PortC to outputs
    ANSEL  = %00000000  ' Make AN0 - AN7 Digital (pins RA0, RA1, RA2, RA3, RA5 on PIC18F26K20)
    ANSELH = %00000000  ' Make AN8 - AN15 Digital (pins RB2, RB3, RB1, RB4, RB0 on PIC18F26K20)
    Sep 2016
    They're in the code, they just didn't copy over into the forum copy/paste for some reason.
    Thanks for the reply,
    Dos
  1. Strange Behavior 12F1822
    By nobner in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2012, 09:11
  2. Strange LCD Behavior
    By chips123 in forum mel PIC BASIC Pro
    Last Post: - 1st November 2009, 01:48
  3. Strange behavior - PORTG.2, 18F8720
    Last Post: - 12th January 2009, 00:30
  4. Strange electrical behavior with PIC16F684
    Last Post: - 28th March 2008, 07:58
  5. 12F629 Strange interupt behavior
    By BGreen in forum mel PIC BASIC Pro
    Last Post: - 25th May 2007, 16:35
