Easy and Accurate Clocks without RTC IC
Results 1 to 19 of 19
    Feb 2003
    Salt Lake City, Utah USA
    Quote Originally Posted by Terry View Post
    Paul,
    In one of you earlier posts on this thread, you mention that you use a 20ppm crystal, can you share your source for this crystal. All the crystals I have found have a 50ppm tolerance at 25 deg and then a another 50ppm over temperature or then a worst case frequency tolerance of 100ppm, I would like to stay away from using a TXCO and 20ppm would be the right amount of acceptable tolerance for my project.
    thanks,
    Terry
    Hi Terry,
    I am not near my lab so I cannot check right now ... however, I know I got them at either Digi-Key or Mouser. I just saw this part http://www.mouser.com/Search/Refine....t=815-ABL-4-B2
    and will check in my lab and confirm if that is what I used. Back when I posted this example I let my trial circuits run for months and found the tolerance to always be +/- 20ppm or less with the xtals I used. I will let you know here shortly.
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Sep 2003
    Vermont
    I use the Abracon line. They have both SMT and through hole packages @20 ppm. They have some higher speed @ 10 ppm. Very reasonable, besides!
    Shouldn't it HzTimer be initialized to $7A120 (dec500000), rather than to $7A12 (dec31250)? And incremented by the same $7A120 for 1/2 second.
    Never mind; now I see you're dividing by $10.
    Aug 2003
    Err, Did you realise you ignored the author of your one second timer when he posted here?
    Anyway, I was looking around for an explaination of why my clock drifts out
    a couple of seconds in a few hours. Now I know.
    I didn't know you could buy different qualities of crystals. Perhaps I should chase a better one.
