Easy and Accurate Clocks without RTC IC
Results 1 to 19 of 19
    Dec 2005
    Paul,
    Clever code, if the crystal oscillator is running at 20 MHz instead of 4 MHz, how would the code be modified, thanks.
    Terry
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    My version of the algorithms are set up around a 4 MHz Xtal. They track 0.5 second intervals. On the half second (Col = 0 ), the colon is turned off, on the whole second (Col = 1), the time and colon are updated.
    A 20MHz Xtal is five times as fast as a 4 MHz. Therefore, with everything the “same” in the code the tracked interval would be 0.1 Sec instead of 0.5 Sec. Although I have not tried this, I believe all you need to do is change the Col variable from a BIT to a BYTE and use it for updating the colon blink and time.
    IF Col = 10 then update time (instead of IF Col = 1)
    IF Col = 5 then turn off blink (instead of the “THEN” part of IF Col =1)
    IF Col = 11 then Col =1 (add after Col=Col+1 to reset Col variable)
    Note, however, that you will have 1/5 the time to do other stuff in between overflows. With a 4 MHz Xtal, this gives over 65 ms. With a 20 MHz Xtal, this gives 13 ms (you may need to watch those serial LCD times)
    Since TMRO is maxed out with the prescaler of 256, the ideal solution would be to move to TMR1 or TMR2 (or to an 18F series where TMR0 = 2^16). With these other timers and a few code changes, you could get longer overflow times with your 20MHz Xtal. I encourage you to see Roman Black's original (www.romanblack.com) - he describes how to get any time period with any Xtal.
    Good Luck,
    Paul Borgmeier
    USA
    Oct 2009
    Default Re: Easy and Accurate Clocks without RTC IC
    Quote Originally Posted by Terry View Post
    Paul,
    Terry
    Ok I know this is an old thread, but having just modified the code to run on an 18F4520 using a 20 Mhz crystal I thought I would post the code here. It also uses a parallel LCD (20 x 4) so hopefully answers one of the other questions raised. The LCD display needs some tidying up to overwrite previous digits (other wise you get 29,39,49 etc until 10 seconds turns over) but then that should be a simple matter to sort out
      __CONFIG    _CONFIG1H, _OSC_HS_1H
      __CONFIG    _CONFIG2L, _PWRT_ON_2L
      __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H
      __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    DEFINE  OSC 20  ; 48 was old config settings 18F4520, 20mhz crystal
    ADCON1 = $0F
    clear
    DEFINE LCD_DREG  PORTB           ' LCD Data port
    DEFINE LCD_DBIT  0               ' starting Data bit (0 or 4)
    DEFINE LCD_EREG  PORTB           ' LCD Enable port
    DEFINE LCD_EBIT  5               '     Enable bit  (on EasyPIC 5 LCD)
    DEFINE LCD_RSREG PORTB           ' LCD Register Select port
    DEFINE LCD_RSBIT 4               '     Register Select bit   (on EasyPIC 5 LCD)
    DEFINE LCD_BITS  4               ' LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 4               ' number of lines on LCD
    DEFINE LCD_COMMANDUS 2000        ' Command delay time in us
    DEFINE LCD_DATAUS 50             ' Data delay time in us
    LED var portA.7
    CMCON=7                'all digital
    T0CON = %11000111
    INTCON=0               'interrupts off
    HzTimer VAR Word         '1/2 second counter (2 Hz)
    HH VAR Byte  ' Hours 0-23
    MM VAR ByTE  ' Minutes 0-59
    SS VAR Byte  ' Seconds 0-59
    col VAR Byte  ' colon 1=on, 0=0ff
    HzTimer=$7A12        'for 1/2 Sec
    HH=12:MM=0:SS=0:col=0 'initial conditions (12:00 O'clock noon)
    LCDOUT $FE,1:FLAGS=0:PAUSE 250:LCDOUT $FE,1:PAUSE 250 ' Initialize LCD
    ClockLoop: IF intcon.2=0 THEN ClockLoop	'Poll for TMRO overflow
    INTCON.2=0 ' Clear TMRO overflow flag
    HzTimer=HzTimer-$1000	'decrement timer count
    IF HzTimer < $1000  THEN
        IF Col=10 THEN    ' update time'
            SS=SS+1
            LED =0    ' Turn off GP1
            IF SS=60 THEN   ' minute
                SS=0
                MM=MM+1
                IF MM=60 THEN    ' hour
                    MM=0
                    HH=HH+1
                    IF HH=24 THEN HH=0
                    IF HH=20 then LED = 1    ' Turn on GP0 at 8:00pm
                   LED =1    ' Turn On  GP1 for 1 second on the hour
                ENDIF                           ' Adjust these to meet your needs
                if MM=15 then LED = 0        ' Turn off GP0 at 8:15pm
        Col=Col+1
        HzTimer=HzTimer+$7A12	' Add 0.5 seconds to count
        ' Do something here but must be less than 65.5 mSec
          if Col=11 then
        Col=1
        LCDOut $FE,$D4,#HH,":",#MM,":",#SS
    GOTO  Main 'forever
