Read array in sequence, and convert it's contents into single variable?
Results 1 to 7 of 7
    Default Read array in sequence, and convert it's contents into single variable?
    Hello, say I have 32 bit array, in each of it's "cells" is written either 1 or 0. I want to read this array in a way, that these cells add next to each other. Say, content of first 4 cells is "1" "1" "0" "1". How can I convert it into single byte variable, which will read as "1101" ?. If there were string variables, then task would be simple, by just reading current array position into string variable, and adding to itself. But in PBP we don't have string variables, how should I ?
    Default Re: Read array in sequence, and convert it's contents into single variable?
    like this maybe
    myarray var byte[4]  ; a 32 bit array
      nbyte  var byte                     ;result
     inx    var byte                         ;start index in array
      x    var byte
    arraywrite myarray,[105,100,10,116] ; fill array
     inx=3                                        ;  start a bit 3
     nbyte=0                                   ;clr result
     for x= 0 to 3                               ;get the 4 bits
     nbyte.0[x] = myarray.0[x+inx]
     next
     serout2 PORTa.0,84, [13,10,"nb ",bin4 nbyte ]
    How do you want to work with it afterwards? did you want to process it as decimal 1101 or binary 1101 or just "string" 1101?
    I want to convert it to decimal and use in that way.
    Sorry, I'm confused on this. You want to take each nibble and convert it to a decimal value, or???
    No, imagine array consists of "1" "0" "1" "1" digits, I want to "merge" them into one binary variable, which I will convert to decimal later.
    so where is the problem ?
    what have you tried ?
  1. Lookup with variable contents??
    By elcrcp in forum mel PIC BASIC Pro
    Last Post: - 17th June 2015, 09:21
  2. Read/write a single bit (MCP23018)
    By vladimir059@hot in forum mel PIC BASIC Pro
    Last Post: - 28th June 2011, 04:11
  3. Saving variable(s) contents before power is removed
    By emavil in forum mel PIC BASIC Pro
    Last Post: - 15th July 2007, 17:26
  4. How do I convert an internal variable into frequency
    By schlaray in forum mel PIC BASIC Pro
    Last Post: - 13th February 2007, 07:26
  5. Convert a word variable to decimal
    Last Post: - 4th December 2004, 20:02
