switching high inductance loads
Results 1 to 13 of 13
    mytekcontrols's Avatar
    mytekcontrols Guest
    kitkat,
    Since you mentioned not having any good software for doing circuit diagrams I thought I'd make a few suggestions of some utilities I have used and recommend. Here is a source for an excellent, and free (with some limitations) circuit and PCB layout package: http://www.cadsoftusa.com/
    (the free version only limits the size of the board you can layout, and allows only 1 page per schematic).
    And if all you are interested in is just doing schematics then this is a very easy to use, and quite good open source solution: http://tinycad.sourceforge.net/
    (this one allows using the clipboard to cut and paste into other windows apps... very nice).
    I hope that helps on the schematic development side. On the other issue of getting resets of the pic when switching solenoids; I found the zero crossing triac (AC) opto isolator approach good for preventing this. If the relay or solenoid load is very small, then no external Triac is required. If not, then driving a suitably rated external Triac with a simple resistor, capacitor snubber network, does the trick. I have successfully done this with massive 220 Vac solenoids switching gears on a 3000 foot cable winch without any gliching problems what-so-ever. If I find the schematics, I'll post them.
    Good luck!
    kitcat's Avatar
    kitcat Guest
    Hi.
    thanks for those suggestions. I shall take a look real soon. I had been wondering what to do about my schematics. As for the schematics you mentioned, if you o have a chance could you have a look and see if you can find them. I am going to start again with this and see if I can't nail it.
    Matt Kitcat
    mytekcontrols Guest
    I found them, but it was part of a project I was subcontracted to do, so I can't post the entire schematic (too bad, since it has a lot of very useful power control related aspects). However I did take a snapshot of the item of interest, and have it shown here:
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=386">
    The circuit shows an MOC3022 being used. This is actually a random crossing device. For zero cross switching, you will want to substitute a MOC3043 (unless you use the PIC to monitor the AC line for zero crossing as I did on this project). Here is the spec sheet for the zero cross part: http://www.jameco.com/wcsstore/Jamec.../277843FSC.pdf
    These are about $0.59 each from Jameco, and will be a drop-in replacement for the MOC3022 device. The external triac can be anything that is suitable for the voltage and load you anticipate for your application.
    The AC source can be any voltage you wish. Although if you want to run this at 200+ volts, it is recommended that the resistors be increased to 180 ohms. Also as I mentioned in an earlier post, you can directly drive small AC loads directly from the opto isolator's output (a very small relay or solenoid).
    By the way here is the Zero Cross Detection circuit I was using on the original project:
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=387">
    The output of the XOR Gate was monitored by the INT0 line of the PIC, and would enable switching of the OPTO's only when the AC was in the zero crossing state. I took this route because I was also doing speed control of 2 motors utilizing phase delayed switching, based on zero cross as the starting point.
    I hope this info is of use to you,
  1. SERIN MIDI out of Synch?
    By jncortes in forum mel PIC BASIC Pro
    Last Post: - 9th June 2009, 21:08
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. confused problem with interrupt in a working program
    By illuminator4 in forum mel PIC BASIC Pro
    Last Post: - 14th November 2008, 18:01
  4. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 03:37
  5. Serin and TMR0
    By capitano in forum mel PIC BASIC Pro
    Last Post: - 17th May 2006, 15:58
