LCD problem
Results 1 to 21 of 21
Thread: LCD problem
    Feb 2005
    Portugal
    This morning i put 2 regulators, but the problem still happens.
    I thing that iīm not overloading my regulator. I'm using 7805 that supports 1A.
    With this morning tests i think that my problem itīs with my 74HCT245. And why? When i put 4.3V on my 74HCT245 i donīt have problems in the display. I see the datasheet and thereīs a diference between 74HCT245 and 74HC245. For HC the condition is VI = GND to VCC For HCT the condition is VI = GND to VCC - 1.5 V. Whatīs this meaning? That i cannot put Vcc to +5V or my inputs/outputs have to be 5-1.5=3.5V????
    Melanie said:
    When everything is connected (and not working) what is the +V on each device?
    In each device i have +4.9V.
    Feb 2005
    Portugal
    As i said i'm giving more news...
    I changed my 74HCT245 to 74HC245 and i have no problems... I donīt understand very well but it works!
    Now i only have one problem
    My MCLR has the circuit attached, but when i close my circuit almost the time doens't do the reset. But if i put my multimeter between pins 1 (MCLR-Vpp) and ground, to measure my voltage it works fine...
    What probably it's happening??
    What can i do?
    Sorry to have strange questions and strange problems, but i'm new in this matter and i like to understand the problems.
    leonel, With the diode in the direction that it is the Processor will never reset with the pushbutton. What is the reason for the diodes direction?
    Dave Purola
    Feb 2005
    Portugal
    Post
    In datasheet of 18F458 pag 23 section 3.0 (Reset) thereīs a schematic. I did a little changes to use a switch and make a reset through a switch... Itīs not the first time i'm using this circuit and in the others have been working!
    I still prefer the KISS engineering... but it's my own opinion.
    how about something like that
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=394&stc=1">
    you can remove the toggle switch...
    In fact to do ICSP i use the above in conjunction with a simple ICSP switcher like that
    <img src=http://www.picbasic.co.uk/forum/attachment.php?attachmentid=163">
    This allow me to do everything for developpement without install/remove the ICSP connector.
    Talking
    Hi, leonel
    Try a Schottky diode ( BAT 85 i.e. ) or Germanium diode ( OA ...) instead of the 1N4148 ... its leakage current will make your reset circuit work better !!!
    that's not very elegant ...but will work !!!
    Feb 2005
    Portugal
    What i did and it works was putting a R=100K between pin 1 and ground, in conjunction with my circuit.
    What's the "KISS engineering"?
    Talking
    Well a pull;-down should be bellow 10K and will affect your current design.
    KISS engineering... not meant to be ofendant by any way...of course
    Keep It Simply Stupid Engineering.
    That's my favorite method.
    Wink
    Everything that avoids a floating pin condition works ....
    as Ralf wrote : RTFM !!! ( for humour here ... but found at page 9 or 10 !!! )
  1. LCD problem with 16F628
    Last Post: - 19th September 2016, 09:28
  2. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 20:48
  3. LCD problem
    By Andre_Pretorius in forum General
    Last Post: - 27th January 2009, 16:47
  4. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  5. Need help with LCD number display.
