Trying now, running it after a "clean boot" process (via msconfig dialog/tabs/checkboxes)... will report back.
OK, safe mode did not help. What Antivirus you have installed? While offline can you disable it?
Then maybe you can list all your installed programs to check whichis conflicting.
Hi picster, I wasn't defending anyone only pointing out frustration does not help . . . have you tried running in xp compatible mode? Have you given it admin status? are you managing your paging file or allowing windoze to do it?
I have not tried in XP compatible mode, but will try that prior to trying it in a virtual machine. I have tried ADMIN status. Windows is managing my paging file, I have 16G of ram installed, and crashes occur in MCS when I've done a clean boot with very little running. No other apps that I use crash on my system, literally, ever. The error is not a BSOD, it's a program crash error (see below, if I can paste the image properly).
Same happens in each of 3 laptops that I've tried this on, so it's not related to video card (which are different), and one was a pristine machine that I had just restored to factory settings. All are DELL.
Yes but it's unusable in safe mode. Sometimes it will go a few days or so without crashing. Other times it will crash 3 times in 10 minutes. With the level of tech support provided, if it works in safe mode, the conclusion will only be "use it in safe mode" and I'm not at all willing to do that. Have you SEEN your screen in safe mode lately?
