is it possible to break PAUSE statement with multiple interrupts?
Results 1 to 6 of 6
    Default is it possible to break PAUSE statement with multiple interrupts?
    Hello, here is my code:
    lcdout $FE,1,"Duration:",#xangrdzlivoba, " us    "
    LCDOUT $FE, $C0,"Delay:", #dakovneba, " ms    "
    triala:
    IF PIRVELI=0 THEN GOSUB DROMINUS
    IF MEORE=0 THEN GOSUB DROPLUS
    IF MESAME=0 THEN GOSUB PAUSAMINUS
    IF MEOTXE=0 THEN GOSUB PAUSAPLUS
    IF PIRVELI=1 AND MEORE=1 AND MESAME=1 AND MEOTXE=1 THEN GOSUB CAVIDA
    GOTO TRIALA
    DROPLUS:
    XANGRDZLIVOBA=XANGRDZLIVOBA+10
    if xangrdzlivoba>10000 then xangrdzlivoba=10000
    lcdout $FE,2,"Duration:",#xangrdzlivoba, " us    "
    PAUSE 50
    DROMINUS:
    XANGRDZLIVOBA=XANGRDZLIVOBA-10
    if xangrdzlivoba<10 then xangrdzlivoba=10
    PAUSE 50
    PAUSAPLUS:
    DAKOVNEBA=DAKOVNEBA+10
    if DAKOVNEBA>10000 then DAKOVNEBA=10000
    PAUSE 50
    PAUSAMINUS:
    DAKOVNEBA=DAKOVNEBA-10
    if DAKOVNEBA<20 then DAKOVNEBA=20
    PAUSE 50
    CAVIDA:
    HIGH ANTEBA
    PAUSEUS XANGRDZLIVOBA
    LOW ANTEBA
    PAUSE DAKOVNEBA 'this causes delay
    It do controls stroboscope, so user presses buttons and sets strobe duration and delay between pulses. The problem is, that when delay is quite long, and code is executing apropriate PAUSE statement, buttons are not operable. So is it possible to add some code, that will end PAUSE statement prematurely, on any key press?
    I've tried to make a loop instead of pause, and check state of all buttons inside it, but since the delay can be quite short, such additional statements slow it down considerably. I'm using PIC16F870 @ 4mhz.
    Aug 2016
    Default Re: is it possible to break PAUSE statement with multiple interrupts?
    Yes, I think it is possible to set a break point using 'pause' command with multiple interrupts.
    Without going into tricks like manipulating the system variables used for the PAUSE statement there's no way to terminate a PAUSE statement prematurely. If you're using interrupts (not ON INTERRUPT though) the program can be made to respond DURING the PAUSE statement but then any time spent handling those events will of course be "added" to the duration of the pause.
    The best way is probably to break the pause duration up in a a lot of shorter durations and check your inputs and what not as part of that loop. I read your response as if that's something you've tried but it's not clear why it didn't work for you. To keep accurate timin you must try Writing the "check-inputs-code" so that it always takes the same amount of time. Then of course I have no idea exactly how acurate you NEED to be.
    If the polling code take 120us to execute then do a loop with PAUSEUS 876 (tweak it match) and GOSUB your polling code each time.
    Yes, what I basically want, is to terminate PAUSE statement, when any key is pressed.
    And like I said, you basically can't without going to low level tricks. Instead my recommendation would be something like this:
    Delay_ms = 1000
    GOSUB WaitHere
    WaitHere:
    For ms = 1 to Delay_ms
      Gosub CheckInputs
      PAUSEUS 900  ' Tweak this to get correct timing, value depends on execution time CheckInputs.
    NEXT
    CheckInputs:
    ' Do whatever here, but no pausing etc
    ' If the delay should be terminated set ms = Delay_ms which will then terminate the FOR-NEXT loop when it returns.
    Oh, thanks, will give it a try.
  1. help in pic Basic Pro "Break statement"
    By boscox in forum mel PIC BASIC Pro
    Last Post: - 25th May 2012, 11:53
  2. PAUSE statement
    By PlantBob in forum mel PIC BASIC Pro
    Last Post: - 19th January 2011, 14:17
  3. DT interrupts and Pause
    By Luckyborg in forum mel PIC BASIC Pro
    Last Post: - 18th February 2009, 22:47
  4. Handeling multiple Interrupts
    By BobSpencerr in forum General
    Last Post: - 1st March 2007, 01:12
  5. Multiple HW Interrupts
    By Radiance in forum mel PIC BASIC Pro
    Last Post: - 13th August 2003, 22:35
