Problems setting config bits on 10F222 part
Results 1 to 10 of 10
Threaded View
  1. #7
    Default Re: Problems setting config bits on 10F222 part
    This is from memory and I've got no way of doublechecking right now but if you want to get to the bottom of it you can always check/verify/try.
    In the .inc file the __CONFIG is enclosed within an ASM/ENDASM block, it gets passed to the assembler as is and it is indented, as it should be.
    When you comment it out of the .inc file and put it in your source file you need to tell the compiler to pass that line to the assembler (just as is the case with the .inc file). You do this by either enclosing it within a ASM/ENDASM block or using the single line ASM directive, @, just as you tried.
    What I suspect happened in your case is that there is no space between the @ and the __CONFIG so __CONFIG ended up in column 1, hence the error (or is it actually only a warning?).
    So, comment it out of the .inc file, then in your source
       __CONFIG _MCLRE_OFF & _CP_OFF & _WDT_ON & _IOFSCS_8MHZ   ; <---- Note the intendation
    or
    @   __CONFIG _MCLRE_OFF & _CP_OFF & _WDT_ON & _IOFSCS_8MHZ   ; <---- Again, note the intendation
  1. how to loop thru setting port bits?
    By wdmagic in forum mel PIC BASIC Pro
    Last Post: - 24th February 2013, 14:38
  2. 16f88 setting config
    By be80be in forum mel PIC BASIC Pro
    Last Post: - 13th December 2012, 16:39
  3. Setting bits
    By bearpawz in forum General
    Last Post: - 28th November 2009, 01:37
  4. Configuration bits setting problem
    Last Post: - 26th August 2009, 18:25
  5. Trouble setting config. bits
    By jswayze in forum mel PIC BASIC Pro
    Last Post: - 13th March 2004, 23:22
