Negative numbers in a lookup table?
Results 1 to 7 of 7
    Default Re: Negative numbers in a lookup table?
    Why sure you can. If the number is between +32767 and -32767 then all you need to do is look at the most significant bit (bit 15) to see if it is positive (bit 15 will be 0) and negative (bit 15 will be 1). Then you can use LOOKUP2 which works with words as output variables. It's in the manual.
    EN82fn
    Aug 2003
    Pretty much any variable is signed if you want. A byte can be 0-126, and anything higher, subtract 126 from it, print with a “-“ in front of it,
    and is also the value of the negative number.
    But that's not really "standard" is it? I'd probably stick to the normal two's complement standard.
    Subtract the value from 256 (if the variable is byte sized) and print a - in front. But really, for presentation purposes etc PBP already supports that with the SDEC modifier.
    If you need to multiply two numbers (A) and (B) where one (B) can be negative then
    A VAR WORD
    B VAR WORD
    Sign VAR BIT
    A = 10
    B = -5
    Sign = B.15
    Result = A * ABS(B)
    Result.15 = Sign
    LCDOUT SDEC Result
    I had to do that, and just used an offset to make them all positive. When it comes time to use the data, I then subtract the offset from the stored number if the stored number is MORE than the offset, OR subtract the number from the OFFSET and set a "negative" flag if the stored number is LESS than the offset.
    Say the range is -50 to +70. Add 50, shifting the range to 0-120. Use these "revised" values for your lookup.
    Now when you do the lookup, you get a value V
    If V > 49 then
    V=V-50
    NEGFLAG=0
    V=50-V 'calculates the difference to restore the original data
    NEGFLAG=1 'sets the negative flag so you can act upon it with calculations if needed
  1. Lookup table not accepting strings
    Last Post: - 17th January 2011, 21:41
  2. How do you create a lookup table?
    By AlexanderWinnig in forum mel PIC BASIC Pro
    Last Post: - 12th November 2010, 14:37
  3. Lookup table syntax.....
    By TerdRatchett in forum mel PIC BASIC Pro
    Last Post: - 19th May 2009, 04:45
  4. Lookup table or Math?
    By ronjodu in forum mel PIC BASIC Pro
    Last Post: - 2nd May 2008, 17:55
  5. Lookup Table
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 10:38
