external clock
Results 1 to 5 of 5
Thread: external clock
    Sep 2016
    Default external clock
    Hello, i am new to programming and am using a pic18f25k22 im trying to set it up to use an external 8mHz oscillator but from looking at the datasheet i am confused about how i do this any help would be appreciated thanks connor
    Default Re: external clock
    IS that an really an oscillator or do you mean a xtal or a resonator, they all have different requirements
    more info is needed and what have you tried ?
    Sep 2010
    Las Vegas, NV
    If you insist on using an external oscillator/resonator/crystal there are some examples of how to hook it up in the datasheet on page 33.
    However, most people would be glad to use the internal frequency selectable oscillator. Saves pins, parts and cost.
    As above, tell us what you've tried and most will steer you in the right direction.
    Sep 2016
    think ive managed to do it now using the following line
    #pragma config FOSC = HSMP
    im new to pic programming and struggling to set the pic up from scratch so the i/o pins are outputs ect
    i am using an 8mHz xtal i will be using the i/o pins as outputs to mulitiplex a 7 segment display
    If i'm not mistaken thats C, so I guess you're on the wrong board.
    George
  1. External clock on 16f819 problem.
    By tasmod in forum mel PIC BASIC Pro
    Last Post: - 27th January 2012, 17:09
  2. Shiftin with external Clock howto ?
    By RFsolution in forum mel PIC BASIC Pro
    Last Post: - 21st September 2011, 16:45
  3. Data Out From External Clock
    By Quin in forum Serial
    Last Post: - 25th October 2008, 09:11
  4. external clock / internal clock
    By grounded in forum General
    Last Post: - 31st May 2008, 17:44
  5. External clock
    By Firegod in forum mel PIC BASIC Pro
    Last Post: - 17th March 2007, 00:53
