LCD problem with 16F628
Results 1 to 26 of 26
    Feb 2005
    GREECE
    Question LCD problem with 16F628
    Good morning to everybody,
    I have a problem with my code.LCD--->16F628
    Please check my code!!!
    Thnks
    ' PicBasic program to demonstrate operation of an LCD in 4-bit mode
    ' LCD should be connected as follows:
    ' LCD PIC
    ' DB4 PortA.0
    ' DB5 PortA.1
    ' DB6 PortA.2
    ' DB7 PortA.3
    ' RS PortA.4 (add 4.7K pullup resistor to 5 volts)
    ' E PortB.3
    ' RW Ground
    ' Vdd 5 volts
    ' Vss Ground
    ' Vo 20K potentiometer (or ground)
    ' DB0-3 No connect
    @ DEVICE pic16F628, INTRC_OSC_NOCLKOUT ' system clock options
    @ DEVICE pic16F628, WDT_ON ' watchdog timer
    @ DEVICE pic16F628, PWRT_ON ' power-on timer
    @ DEVICE pic16F628, MCLR_OFF ' master clear options (internal)
    @ DEVICE pic16F628, BOD_ON ' brown-out detect
    @ DEVICE pic16F628, LVP_OFF ' low-voltage programming
    @ DEVICE pic16F628, CPD_OFF ' data memory code Protect
    @ DEVICE pic16F628, PROTECT_OFF ' program code protection
    Define LCD_BITS 4 ' 4-bit interface
    Define LCD_LINES 2 ' 2 line LCD
    ' LCD PIC
    ' DB4 PortA.0
    ' DB5 PortA.1
    ' DB6 PortA.2
    ' DB7 PortA.3
    Define LCD_DREG PORTA
    Define LCD_DBIT 0
    Define LCD_RSREG PORTA
    Define LCD_RSBIT 4
    ' E PortB.3
    Define LCD_EREG PORTB
    Define LCD_EBIT 3
    ' RW Ground
    ' Vdd 5 volts
    ' Vss Ground
    ' Vo 20K potentiometer (wire wiper to Vo, adjust for contrast)
    ' DB0-3 No connect
    Define LCD_COMMANDUS 2000 ' Adjust for slower LCD modules
    Define LCD_DATAUS 50
    INCLUDE "MODEDEFS.BAS"
    INTCON = 0 ' Disable interrupts
    CMCON = 7
    Pause 500 ' Wait for LCD to startup
    loop: Lcdout $fe, 1 ' Clear LCD screen
    Lcdout "By:Geronikolos" ' Display Hello
    Pause 500 ' Wait .5 second
    Lcdout $fe,$c0,"World" ' Clear LCD screen
    Lcdout $fe,$c0,"Hello" ' Clear LCD screen
    Goto loop ' Do it forever
    You might want to try these two things...
    1. Ground D0-D3 on the LCD
    Don't leave those lines not connected and floating - it's bad practice.
    2. Increase the inital Pause 500 to Pause 1000
    Pause 500 may be insufficient for your LCD to initialise at power-on.
    Why don't you want to use A.5 for E-Bit? That way the whole of PORTB is free for your applications use. If you used A.6 for the RS Bit, you wouldn't need that Resistor either.
    Additionally, although this has nothing to do with the LCD... INTCON = 0 is unnescessary as Interrupts are disabled by default.
    Feb 2005
    GREECE
    Melanie,
    Thanks for your advice but nothing.I ground D0-D3 on the LCD and I change the inital Pause to 1000 and 1500.
    I saw on my lcd all first line with black blocks.
    Please advice
    1. Check the SPELLING of your LCD Defines... they must be EXACT because the compiler will not flag errors if have made a mistake there.
    2. Check that you have not mistakenly swapped your E or RS bits and connected them the wrong way around...
    3. Turn down your contrast... if it's too high then you might be swamping any displayed data with black blocks.
    4. Finally, double-check your hardware connections against your DEFINES.
    There are no problems or issues connecting LCDs to a 16F628 on internal oscillator with internal MCLR therefore it must be something in your connection...
    Feb 2005
    GREECE
    Question
    The compiler is OK.No errors.
    May my programmer cause the problem?
    Because the circuit and the program was working in the past.
    Feb 2005
    GREECE
    Melanie,
    I check my circuit and it seems ok.
    That is the diargam of it.
    Please have a look.
    Well, let's make sure your PIC is working...
    Got an LED? Connect it say between PortB.0 with a series Resistor (anything between 220R and 470R) and Vss (0v).
    After your LCD define put...
    LED var PORTB.0
    In your main loop, anywhere put...
    Toggle LED
    When the PIC runs, your LED should blink...
    Feb 2005
    GREECE
    Dear Melanie,
    You are right. My PIC is not working but I can not understand why?
    I try to blink a led but nothing.Where is the problem with my code?
    I attach my code and the hex file.
    PLEASE HELP MEEEEEEEEEEEEEEEEEEEEEEE.
    Feb 2005
    GREECE
    IS ALL THAT OK TO RUN MY PIC WITH INTERNAL OSC?
    I have to write DEFINE OSC 4?
    There is no attachment... nail it to your posting and I will check it...
    Feb 2005
    GREECE
    HERE IT IS!!!
    Thanks Melanie
    Little busy this morning, but I'll breadboard a 16F628 later in the day with your code and let you know...
    n0oxv's Avatar
    n0oxv Guest
    Melanie,
    You are tooo good !
    >"Melanie, You are tooo good !"
    Yup, that's what all the boys say!
    You may or may not like what I'll report...
    1. Taking your posted LCD_HEX file and burning a PIC16F628 with it produces all Black Squares just as you say. So here I confirm the same result. I do notice one anomaly - your HEX of the same program is twice the size of mine.
    2. But, taking your posted LCD_BAS file, renamed it LCD1, compiled it (with absolutely NO changes) with PBP2.46, burned the same PIC and it WORKS!!!! See appended picture. Try it with my HEX which I named LCD1.HEX.
    I used the compile line...
    PBP -p16F628 LCD1 -v
    Therefore, either...
    1. Your posted HEX file is not a true compilation of the posted BAS file...
    2. You are using a very old compiler which may have problems...
    3. Your compiler is corrupt...
    4. You are using some external IDE (such as MCS) which is causing you a problem.
    5. If you are compiling using Microchips MPASM the version you have may be old or corrupt.
    6. Or any other reason such as alien invasion of your neighbourhood...
    Feb 2005
    GREECE
    Thanks Thanks....Thanks Melanie,
    I do not have words to thank you...
    I will try it and I will inform you.
    Default Re: LCD problem with 16F628
    Bumping an 10 year old tread....
    I also have problems with 16F628A and 1602 LCD
    PCON=%00001011 'set intosc to 4mhz
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 4
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 5
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 1500
    DEFINE LCD_DATAUS 44
    LCDOUT $FE, "SACDELI   "
    PAUSE 5000
    PORTB.0 - PORTB.1 are connected to D4-D7 pins of LCD
    PORTB.5 is connected to RS pin
    PORTB.6 is connected to E pin.
    All hardware 100% verified and working. But still no display.
    Your code says RS is PortB.4 while you say it's PortB.5.
    Your code says E us PortB.5 while you say it's PortB.6.
    Thanks, fixed that, but still does not works...
    Jul 2008
    TURKIYE-KONYA
    can you share your config settings?
    ;----[16F628A Hardware Configuration]-------------------------------------------
    #IF __PROCESSOR__ = "16F628A"
      #DEFINE MCU_FOUND 1
    cfg = _INTOSC_OSC_NOCLKOUT    ; INTOSC oscillator: I/O function on RA6/OSC2/CLKOUT pin, I/O function on RA7/OSC1/CLKIN
    cfg&= _WDT_ON                 ; WDT enabled
    cfg&= _PWRTE_OFF              ; PWRT disabled
    cfg&= _MCLRE_OFF              ; RA5/MCLR/VPP pin function is digital input, MCLR internally tied to VDD
    cfg&= _BODEN_ON               ; BOD enabled
    cfg&= _LVP_OFF                ; RB4/PGM pin has digital I/O function, HV on MCLR must be used for programming
    cfg&= DATA_CP_OFF             ; Data memory code protection off
    cfg&= _CP_OFF                 ; Code protection off
      __CONFIG cfg
    #ENDIF
    ;----[Verify Configs have been specified for Selected Processor]----------------
    ;       Note: Only include this routine once, after all #CONFIG blocks
    #IFNDEF MCU_FOUND
      #ERROR "No CONFIGs found for [" + __PROCESSOR__ +"]"
    #ENDIF
    Include "Modedefs.bas"
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSBIT 4
    DEFINE LCD_EBIT 5
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    PAUSE 5000
    not suprised , it's certainly an odd use of the lcdout 254 directive
    Nice one Richard, don't know how I missed that!
    Haha thanks!
    Fixed it. But there were other issues too, MCU itself was also defective, replaced it, and everything works now just fine.
    I guess not then :-)
    It was working, but at certain moment, when swapping LCDs, I've applied power to MCU in reverse polarity LCD survived ,MCU - not.
    Aug 2016
    Please see below thread discussion. This may help you.
    https://www.ccsinfo.com/forum/viewtopic.php?t=42284
  1. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 20:48
  2. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  3. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  5. Gps with 16f628
    By dragons_fire in forum mel PIC BASIC Pro
    Last Post: - 8th June 2006, 04:38
