Timer SubRoutine
Results 1 to 8 of 8
    Apr 2016
    Plainfield, Illinois
    Default Timer SubRoutine
    I'm using a 16f616 - but can be changed. I need to do 2 things at same time. I need a timer that has 2 stages - 1 minute on, 5 minutes off (controlling a relay). At the same time I need to monitor an analog voltage and be able to react to it while its timing.
    Right now I'm trying a rather crude method by going to a sub routine that pauses 250 ms, adds a count to a variable, and returns. I keep track of 1 minute and 5 minutes that way by comparing to te variable. In same main, I'm doing the analog voltage monitoring.
    Whats a better way to keep track of time? It does not have to be that accurate - 5% is ok..
    My dad never liked you...
    Default Re: Timer SubRoutine
    set up a one minute timer, a very simple state machine and a one byte counter. From init your in 1min state, do your 1min task, then go to 5 min state which adds on to the one byte counter until it equals 5, then do your 5 min task, repeat .............
    What an odd sig you have.
    George
    If you don't want to create your own timer. You could use DT's "Elapsed Timer" include . Then monitor the minutes like towlerg suggested.
    http://www.picbasic.co.uk/forum/show...light=dt+timer
    Maybe like this?
        Include "Elapsed.pbp"
        Ticks    var byte   ' 1/100th of a second
        Seconds  var byte   ' 0-59
        Minutes  var byte   ' 0-59
        Hours    var byte   ' 0-23
        Days     var word   ' 0-65535
        Gosub ResetTime    ' Reset Time to  0d-00:00:00.00
        Gosub StartTimer   ' Start the Elapsed Timer
    MainLoop:
    Read ADC
     If minutes =0 then
       Relay on
     If minutes =1 then
       	Relay off
     If minutes = 6 then
     	Gosub ResetTime 'Reset to 0 minutes
    MainLoop
    I had similar circuit for a battery charger setup. I used 2 main loops, 1 for off and 1 for on. you can use for-next or while loops. set the counts based on how often you want to check the a/d values and then pause in loop....... for the 1 minute loop, pause 100, check the a/d (10 times a second) and the loop count would be 600, then either exit loop because of a/d or at end of loop, turn off relay and jump into 5 minute loop. The instructions in the looping take little time but you can adjust the pause or loop count to make the timing more correct.
    Maybe try using the TMR0 interrupt. You'll need to configure the TRIS and ANSEL registers to your specific peripherals. It's basically a clock that runs in the background. Every 60th of a second it goes to the dualcounter subroutine (or whatever subroutine you tell it to go to) without you having to call it so that you're free to write code to do other things. The last three bits of the OPTION_REG set up the prescaler which is what tells it how often to interrupt. I'm not exactly sure, but I think 1:64 is about 1/60th of a second. You may need to tweak that a bit though.
    #config
        __CONFIG _CP_OFF & _WDTE_OFF & _BOREN_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT & _MCLRE_OFF & _IOSCFS_8MHZ
    #endconfig
    ADCON0 = %00000000
    ADCON1 = %00110000
    ANSEL = %00000110
    define ADC_SAMPLEUS 50
    define ADC_BITS 8
    DEFINE ADC_CLOCK 3
    CM1CON0 = %00000000
    CM2CON0 = %00000000
    TRISA = %00001111
    TRISC = %00000000
        ' Set TMR0 interrupt prescaler to 1:64
        OPTION_REG = %10000101        ' Set TMR0 configuration and enable PORTB pullups
        INTCON = %10100000           ' Enable TMR0 interrupts
        On Interrupt Goto dualcounter
    1minutecounter var word
    5minutecounter var word
    MAIN:
         ' insert main code here
         if 1minutecounter > 3600 then
              ' insert code to handle 1 minute timer here
              1minutecounter = 0          ' clear counter
         if 5minutecounter > 18000 then
              ' insert code to hand 5 minute time here
              5minutecounter = 0          'clear counter
    goto MAIN
    ''''''''''''''''''''''''''''''''''''''''''''''''''''''''INTERRUPT'''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''
    Disable                                 ' Disable interrupts during interrupt handler
    dualcounter:                                    ' Interrupt routine to handle each timer tick
        1minutecounter = 1minutecounter + 1            ' add 1 on every interrupt
        5minutecounter = 5minutecounter + 1
    tiexit:
       INTCON.2 = 0                             ' Reset timer interrupt flag
       Resume
    enable
    what speed is the PIC clock? (thats what drives the timers in most cases)
    George
    Quote Originally Posted by towlerg View Post
    I believe the 16F616 has options for either 4MHz or 8MHz internal clock.
    Using the Mikro timer calculator @ 8MHz
    'Timer1
    'Prescaler 1:4; TMR1 Preload = 15536; Actual Interrupt Time : 100 ms
    'Place/Copy this part in declaration section
    sub procedure InitTimer1()
      T1CON	 = 0x21
      TMR1IF_bit	 = 0
      TMR1H	 = 0x3C
      TMR1L	 = 0xB0
      TMR1IE_bit	 = 1
      INTCON	 = 0xC0
    end sub
    sub procedure Interrupt()
      if (TMR1IF_bit) then
        TMR1IF_bit = 0
        TMR1H	 = 0x3C
        TMR1L	 = 0xB0
        'Enter your code here
      end if
    end sub
    Of course the syntax is wrong but the values are correct. I couldn't get 1 second so I did 0.1 second. Same principle count to 10 for one sec and 50 for five sec.
    George
  1. Subroutine placement - must they come first?
    Last Post: - 28th August 2012, 12:10
  2. Pulsin within subroutine
    By Wesley in forum mel PIC BASIC Pro
    Last Post: - 10th January 2009, 23:05
  3. subroutine with hserin
    By volcane in forum mel PIC BASIC Pro
    Last Post: - 19th December 2007, 02:56
  4. subroutine question
    By maus in forum mel PIC BASIC Pro
    Last Post: - 11th September 2006, 21:36
  5. subroutine for picbasic
    By jojokatada in forum mel PIC BASIC Pro
    Last Post: - 19th February 2005, 18:58
