Pullup confusion 12c508a
Results 1 to 5 of 5
    Default Pullup confusion 12c508a
    saw this but WPUB must be wrong -- creates an error
    option_reg.7=0 ' Enable WPUs by individual pin
    WPUB = %11110000 'enable weak pullups on RB7, RB6, RB5 & RB4
    anyway -- trying to make this easy -- never used the pullups before.
    INTCON2.7 ?
    I'm seeing all sorts of conflicting internet crap about it and pullups are not not even mentioned in my PBP manual.
    Just trying to enable a pullup on GPIO 1 on a 12c508 and all other ports are output. HELP ! -- THANKS
    Default Re: Pullup confusion 12c508a
    That chip is so old I am afraid to answer.
    Looking at page 17 of the data sheet.
    It looks like you would set the option register bit 6 to 0
    OPTION.6 = 0 'sets weak pullups on gp0,gp1 and gp3
    Add: Read this also
    http://melabs.com/support/12-bit.htm
    Jan 2011
    Sydney, Australia
    Hi Michael,
    The PIC12C508A doesn't have a PORTB so your WPUB statement will obviously create an error.
    As mark_s has already stated, setting option register bit 6 to 0 will enable weak pull ups on GP0, GP1 and GP3
    These pins must be set as inputs.
    Note, hard pull-ups can always be implemented instead of weak pull-ups.
    I trust this helps.
    Cheers
    Barry
    VK2XBP
    Well actually I'm going to use a 12F675 as I now find out I can get it programmed. So, on a 12F675 -- how would I enable a pullup on pin 6 GPIO.1 ?
    THANKS much.
    By the way, "weak" pullup must mean what? Current capabiltiy of the resistor or something?
    Try this for setting the pull-up on GPIO.1
    OPTION_REG.7 = 0 ' Set global GPPU
    WPU.1 = 1             'pull-up on gpio1 enabled
  1. help for 12C508A
    By dagger in forum General
    Last Post: - 30th August 2010, 23:25
  2. neebee wants to know pullup or pulldown?
    By lecoind in forum mel PIC BASIC Pro
    Last Post: - 24th May 2009, 03:36
  3. picbasic +12c508a+soft_stack error
    By omid_juve in forum mel PIC BASIC Pro
    Last Post: - 4th January 2008, 20:11
  4. 12c508A -- Using more Legs...
    By guest_05 in forum mel PIC BASIC Pro
    Last Post: - 14th August 2007, 12:12
  5. 12c508a Device Config. And Burning Issues
    By sayzer in forum mel PIC BASIC Pro
    Last Post: - 29th March 2006, 16:50
