try something like this
slightly altered for a pic16f1825
;pic16f1825
             __config        _CONFIG1,    _FOSC_INTOSC & _CP_OFF & _WDTE_OFF &  _PWRTE_ON  &  _MCLRE_ON  & _CLKOUTEN_OFF
              __config      _CONFIG2, _PLLEN_OFF & _LVP_OFF
ADCON0 = %00000000
ADCON1 = %00110000
'ANSEL = %00000110       ;pic16f1825
ANSELA = %00000100        ;pot is on   porta.2  an2
define ADC_SAMPLEUS 50
define ADC_BITS 8
DEFINE ADC_CLOCK 3
'CM1CON0 = %00000000     ;pic16f1825
'CM2CON0 = %00000000     ;pic16f1825
TRISA = %00001110        ;porta.0 used for debug
TRISC = %00000000
    porta.0=1              ;porta.0 used for debug
    DEFINE DEBUG_REG PORTA
    DEFINE DEBUG_BIT 0      ;  if not used for pwr
    DEFINE DEBUG_BAUD 9600
    DEFINE DEBUG_MODE 0
    ' Set TMR0 interrupt prescaler to 1:128
    OPTION_REG = %10000110        ' Set TMR0 configuration and enable PORTB pullups
    INTCON = %10100000           ' Enable TMR0 interrupts
    osccon=$68   ;pic16f1825
    On Interrupt Goto tickint
    '    Hardware connection
    CS          VAR PORTA.5
    SCK         VAR PORTC.2
    SDI          VAR PORTC.1
    tempoLED var PORTC.0
'    tempobutton var PORTA.0      ;porta.0 used for debug
'    bypassbutton var PORTA.3     ;mclr used on pic16f1825
    bypassLED var PORTC.4
    fetA var PORTC.5
    fetB var PORTA.4
    fetC var PORTC.3
    '    Variables definition
'    w var byte                          ' division toggle switch
    x var byte                          ' delay time knob
    xprevious var byte
'    z var byte
'    ticks var word
    tapcount var word
    LEDcounter var word
'    LEDcounterlimit var word
    LEDrate var byte
'    trailsmode var byte
'    trailsmodecounter var word
'    LEDon var byte
'    LEDoff var byte
     pause 2000
    Debug "Start",13 ,10
    '    begin in bypass
    tempoLED = 0
    fetA = 0
    fetB = 0
    fetC = 1
    bypassLED = 0
'    trailsmode = 0
    gosub readpot
    gosub movepot
    if xprevious <= 0 then
        xprevious = 1
        if (LEDcounter // LEDrate) > (LEDrate>>1)   then
            tempoLED = 1
            tempoLED = 0
        gosub potcheck
if !  LEDcounter//4==0 then
       Debug 13 ,10 , #LEDcounter ,9,#(LEDcounter // LEDrate),9,#LEDrate
potcheck:
        gosub readpot
'        if x <= 0 then     why ??????????????????????????????????
'            x = 1
'        endif
       ;if x >= xprevious + 5 or x <= xprevious - 5 then               ' analog potentiometer debounce tolerance
       if abs ( xprevious-x) > 4 then
            gosub movepot
movepot:
        CS = 0
        shiftout SDI, SCK, 1, [00000000,x]
        shiftout SDI, SCK, 1, [00010000,x]
        CS = 1
        xprevious = x
        gosub tempoLEDadjust
readpot
    adcin 2,x
    x = 8 max x      ;stop led from shutting down  completely
'    pause 10     why ??????
tempoLEDadjust:                                           '  compensate for TMR0 not being 1:1 with actual delay time
    LEDrate = x/2
'    LEDcounterlimit = LEDrate + 1                       'counterlimit must always be 1 greater than rate
'    LEDcounter = 0                                       ' reset LED counter
Disable                                 ' Disable interrupts during interrupt handler
tickint:                                    ' Interrupt routine to handle each timer tick
    LEDcounter = LEDcounter + 1            ' add 1 to LEDcounter on every interrupt
'   if LEDcounter > LEDcounterlimit then      ' prevent LEDcounter from overflowing
'        LEDcounter = 0
'   endif
tiexit:
   INTCON.2 = 0                             ' Reset timer interrupt flag
   Resume
enable
