FREQOUT command for continuous operation
Results 1 to 10 of 10
    Jan 2011
    Sydney, Australia
    Default FREQOUT command for continuous operation
    Hi All,
    I am looking to generate a continuous 50Hz sine wave output using the FREQOUT command.
    From the "good book", the command is FREQOUT, Pin, Onms, Frequency1, {Frequency2}
    My initial idea was to set the Onms equal to zero to achieve continuous operation however this does not work (only operates for ~66 seconds).
    Here is my trial code using PIC12F615:
    '*  Name    : 50Hz Sinewave Generator                           *
    '*  Author  : Barry Phillips                                    *
    '*  Notice  : Copyright (c) 2016 DFAD                           *
    '*  Date    : 5/09/2016                                         *
    '*  Notes   : 50Hz Sinewave Generator using PIC12F615           *
    	__config _INTOSCIO & _WDTE_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _IOSCFS8 & _BOREN_OFF
    ;----[DEFINEs]------------------------------------------------------------------
    DEFINE OSC 8
    ;----[Initialize]---------------------------------------------------------------
    ADCON0.0 = 0   	; Disable ADC
    CMCON0.7 = 0    	; Disable comparator
    TRISIO = 0		; All GPIO pins as Outputs
    ANSEL  = 0		; All GPIO pins as digital I/O
    ;----[Main Program Loop]--------------------------------------------------------
        Freqout GPIO.0, 0, 50
    	GPIO.0 = 0       ; Set pin low to capture rollout of command execution
    	PAUSE 2000     ; Pause 2 seconds to accentuate rollout capture period
    GOTO Main
    Any suggestions how the FREQOUT command can be structured for continuous operation?
    Cheers
    Barry
    VK2XBP
    Default Re: FREQOUT command for continuous operation
    Sorry, can't help with FREQOUT but if I'm not mistaken the 12F615 has a PWM module, I'd suggest you use that.
    Create a lookup table for a sine function containing say 20 entries. Cycle thru it at 1ms per step and you have your 50Hz output.
    But then generating a 50Hz sinewave may be a job for some analog circuitry instead of a PIC.
    Aug 2003
    You won’t get it continuous, it makes a call to an assembler routine itself with the arguments passed to it.
    Failing the hardware PWM, DTs Elapsed Timer code is already clocking at 100Hz by default,
    so you could toggle a pin in the ISR and there’s your 50Hz.
    For better accuracy, toggle a bit, and write the bit to the port so you don’t have a timing change depending on the state.
    flipflop = flipflop + 1 ‘ if variable is a bit it will flip flop
    portb.x = flipflop
    Jan 2011
    Sydney, Australia
    Thanks Henrik and Art for your responses.
    Two things that should have been revealed in my original post:
    1/. The trial code using PIC12F615 was only done because I had that particular chip on hand. The proposed chip for this project is PIC12F1822
    2/. The final design needs to be switch selectable between 50Hz and 60Hz
    Henrik, my original intention was to use a wein bridge oscillator. The fundamentals of this type of circuit are quite straight-forward however the tricky part is the associated circuitry required to ensure a clean signal with constant amplitude. This is why I decided to go with a PIC solution.
    Art, wouldn't your DT's elapsed timer solution result in a square wave output?
    I the event that the FREQOUT approach did not work as expected, my fall back position has always been to use a sine wave lookup table.
    I understand the concept but will need to do some more reading to fully understand the requirements and how to implement it for my application.
    Cheers
    Barry
    VK2XBP
    should be easy with a PIC12F1822 @32mhz or reduce the samples to suit,
    my idea would be something like this
    simple halfwave sin lu table [50 points per cycle]
    15,47,77,106,134,160,183,204,221,235,246,252,255,2 54,250,241,229,213,194,172,147,121,92,62,31
    set ccp to say 32khz carrier or whatever [make sure 10 bit resolution is viable]
    cycle through the table every 400uS
    set pulse width(10 bit) to 512+ lu value
    next half
    set pulse width(10 bit) to 512 - lu value
    rinse repeat
    for 60 hz cycle every 330 uS
    at the o/p filter out carrier
    Jan 2011
    Sydney, Australia
    Thanks Richard.
    Your sine lu table appears non-symmetrical. Have you done this for a reason?
    Cheers
    Barry
    VK2XBP
  1. FREQOUT command
    By Art in forum mel PIC BASIC Pro
    Last Post: - 8th February 2015, 06:21
  2. Freqout ? ? ?
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2009, 00:39
  3. bootloader Freqout problems
    By handgio in forum mel PIC BASIC Pro
    Last Post: - 5th December 2007, 13:38
  4. RPM Counting Continuous
    By CluckShot in forum mel PIC BASIC Pro
    Last Post: - 25th May 2007, 12:37
  5. FREQOUT delays
    Last Post: - 6th December 2003, 23:49
