COUNT never counts properly! (16F870)
Results 1 to 10 of 10
    Default Re: COUNT never counts properly! (16F870)
    Above code is launched, when signal on input pin arrives, I just missed that line here.
    I discarded the COUNT statement, and wrote software substitute, which accurately counts amount of pulses:
     UIDEDA:
     if pulsi=1 then
     FOR N=0 TO 300 'this is length of capture period, 300 for 16F870 @ 4mhz means approx 15ms.
     IF PULSI=1 THEN
     A=A+c
     c=0
     d=1
     B=B+d
     d=0
     c=1
     NEXT
     IF A<>0 AND B<>0 THEN
     lcdout $FE,2, "A=",#A, "    "
     lcdout $FE,$C0,"B=",#B, "    "
     A=0
     B=0
     GOTO UIDEDA
    I'm interested, why count never works as it should.
    Sounds like noise to me.... Try a schmidt trigger between what you are counting and the pic.
    EN82fn
    If it was noise issue, why my code works perfectly?
    Aug 2003
    The manual says with a 4MHz oscillator as you have, the pin is sampled every 20us which is way too slow for the fractional pulse durations you stated.
    The different results can easily be explained since any low or high period could be entirely missed.
    Your code is still pretty slow.
    The fastest I can think of right now in PBP is this:
    newbitstate var bit
    oldbitstate var bit
    counter var word
    count var word
    duration var word
    newbitstate = 0
    oldbitstate = 0
    duration = 9000 ‘ set duration to sample the input
    count = 0 ‘ reset count
    for counter = 0 to duration
    newbitstate = portb.0
    if newbitstate != oldbitstate then
    count = count + 1
    oldbitstate = newbitstate
    next duration
    Then Count will be the number of pin changes.
    To get the pulse count, rather than check in the routine and slow it down,
    just divide Count by 2 at the end, to get the number of rising edges,
    and if the remainder is 1, the duration ended while the port pin was high.
    0.8ms=800us, so it fits very well
    Aug 2003
    lol I was reading ms as microseconds.
    If your code works better than Count then use it I’d sure like to see a disassembly of Count in your loop though, which I don’t have the tools to do handy at the moment.
  1. Can't access Port A with PBP on 16F870.
    Last Post: - 16th April 2013, 12:28
  2. Replies: 23
    Last Post: - 16th September 2010, 17:52
  3. Replies: 1
    Last Post: - 7th December 2009, 17:35
  4. Saving COUNTs?
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 19th April 2009, 18:55
  5. Help needed with 16F870 ADC
    By srob in forum mel PIC BASIC
    Last Post: - 10th May 2008, 14:14
