18f252-i/sp
Results 1 to 5 of 5
Thread: 18f252-i/sp
    Sep 2005
    Default Re: 18f252-i/sp
    Thanks for the reply. I am using a 9600 baud rate, and the clock is set as "HS" with a 20 mHz resonator. The code has worked for a couple of years, but sometimes it will not work with some PIC chips. The code for this project is very long, and I am working on getting the representative code posted.
    Aha, 20mHz - there's your proplem...just kidding - you mean 20MHz ;-)
    Did you use the same PCB, same resonator and everthing else and ONLY swapped the PIC when 4 out of 10 didn't work? Or was it actually 4 out of 10 boards that didn't work?
    Datasheet for the specific resonator you're using? Short of that, measure the actual bit-time generated to verify at which frequency the PIC is ACTUALLY running.
  1. 18f252
    By Meriachee in forum mel PIC BASIC Pro
    Last Post: - 28th July 2009, 02:32
  2. 18F252 config
    By mpardinho in forum mel PIC BASIC Pro
    Last Post: - 16th July 2008, 20:19
  3. 18F252 needs a jumpstart
    By BOB012806 in forum General
    Last Post: - 5th December 2007, 15:21
  4. MC Studio and 18F252
    By trust issues in forum mel PIC BASIC Pro
    Last Post: - 29th October 2004, 14:49
  5. Need help with migration 16F876 -> 18F252
    By NavMicroSystems in forum mel PIC BASIC Pro
    Last Post: - 24th February 2004, 16:22
