Installing today
Results 1 to 3 of 3
    Default Installing today
    Later on today I'm going to install --
    Micro code studio -- PBpro (2.46a) and Epic programmer. It's been several years since I've used these and if I remember right, I had a problem way back when.
    Does the programmer need to be installed before PBpro? Or vice versa? Or what order should I install everything? I definitely remember there was an issue based on the order you install things (even called Melabs about it).
    Also, (if anyone knows off hand), will my PBpro version 2.46a handle a 12C675 ? (It's an old version I know -- maybe I'll be entitled to an upgrade). Thanks much.
    Default Re: Installing today
    I can't say anything about the programmer you have.
    As far as PBP and MCS goes I don't think it matters really but MCS needs to know where PBP is installed and it can find it for you automatically but that obviously required PBP to be installed. So programmer aside, I'd install PBP first, then MCS.
    The 12F675 was added in version 2.42, but 12C675, is that a typo?
    Anyway, you can see at which version a certain device was added here.
    yes typo -- thanks.
    I'll install the epic first, I think that's what I need.
  1. Wow! Lotsa Trolls here today!
    By andywpg in forum Off Topic
    Last Post: - 23rd December 2013, 03:37
  2. Today's Post Search or the Missing Link
    By mackrackit in forum Off Topic
    Last Post: - 1st May 2010, 15:45
  3. Installing PICBASIC PRO
    By tiredengr in forum mel PIC BASIC Pro
    Last Post: - 10th June 2009, 04:12
  4. 6 birthdays today
    By JD123 in forum Off Topic
    Last Post: - 5th April 2008, 17:07
