VFD Display Brightness & Lcdout
Results 1 to 5 of 5
    Default Re: VFD Display Brightness & Lcdout
    You realy can't mess with RS, it is Instruction/Data register select (0=Instruction 1=Data). From the datasheet -
    George
    Aug 2003
    Of course you can. You can mess with any of the signal pins as much as you like.
    It's only on the falling edge of the Enable pin that the state of all other pins are latched to the LCD.
    Hence you can connect multiple LCD modules to all the same pins, but they each need their own Enable pin.
    What I think will happen if you set your own state for RS and then send a command with LCDOUT,
    is PBP will change straight back to what it wants.
    Aug 2011
    I don't think you have to mess with RS. Looking at the datasheet for the VFD it says this:
    One byte data (RS=1) which follows the "Function Set Command" is considered as brightness data.
    When a command (RS=0) is written after the "Function Set Command", the brightness control
    function is not initiated. Screen brightness is as follows.
    So it sounds like the brightness byte goes out as normal data would... you just have to send it right after a Function Set Command byte.
    Try something like this:
    LCDOUT $FE, $20, $03 'FS=4-bit mode and 25% brightness
  1. Winstar OLED Display Problem with lcdout comands
    By bubbleless in forum mel PIC BASIC Pro
    Last Post: - 31st December 2019, 06:53
  2. Replies: 1
    Last Post: - 28th April 2011, 19:02
  3. User Selectable LED Brightness
    Last Post: - 10th April 2005, 19:24
  4. LCDOUT & interrupts
    By lab310 in forum mel PIC BASIC Pro
    Last Post: - 8th April 2005, 12:59
  5. LCDout Command w/ LCD 4x40 display
    By beto in forum mel PIC BASIC Pro
    Last Post: - 21st January 2005, 02:22
