Please help configure 16F676
Results 1 to 2 of 2
    Default Please help configure 16F676
    I'm using a 16F676. The program was working fine till I changed the hardware to use PORTA.3 as a digital input to recognize a pushbutton. Now as soon as the button is pressed the whole thing locks up and I have to turn the power off to get it to reset.
    I know I need to turn MCLRE off. I think I did that, but obviously I did something wrong or I've left something out. Please help me figure out how to use PORTA.3 as a digital input.
    FYI, PORTA.1/AN1 and PORTA.2/AN2 are connected to potentiometers and being used as analog inputs.
    #config
        __CONFIG _CP_OFF & _PWRTE_ON & _INTRC_OSC_NOCLKOUT& _MCLRE_OFF
    #endconfig
    ADCON1 = %00000000
    ANSEL = %00000110
    CMCON = %00000111
    TRISA = %00001111
    TRISC = %00000000
    ' Set TMR0 to interrupt every 16.384 milliseconds
       OPTION_REG = %10000101        ' Set TMR0 configuration and enable PORTB pullups
       INTCON = %10100000           ' Enable TMR0 interrupts
       On Interrupt Goto tickint
        '    Hardware connection
        CS          VAR PORTA.5        ' digital potentiometer SPI connection
        SCK         VAR PORTC.2        ' digital potentiometer SPI connection
        SDI          VAR PORTC.1        ' digital potentiometer SPI connection
        tempobutton var PORTA.0        ' push button 1
        tempoLED var PORTC.0        ' push button 1 status LED
        trailsbutton var PORTA.3        ' push button 2
        trailsLED var PORTC.4        ' push button 2 status LED
        mosA var PORTC.5        ' MOSFET switch A
        mosB var PORTA.4        ' MOSFET switch B
        mosC var PORTC.3        ' MSOFET switch C
    Sep 2010
    Las Vegas, NV
    Default Re: Please help configure 16F676
    Just guessing here but the spacing after noclockout might not recognize the ampersand and therefore the mclre_off config. Could it be that easy?
  1. Configure Debug @ runtime?
    By dhouston in forum Serial
    Last Post: - 11th November 2011, 22:04
  2. how to configure external oscillator
    By itsssyam in forum mel PIC BASIC Pro
    Last Post: - 17th March 2011, 13:15
  3. CONFIGURE & OSCCON & meProg configure
    By SUNFLOWER in forum mel PIC BASIC Pro
    Last Post: - 19th February 2011, 22:25
  4. How do I configure the PIC16F737?
    By LinkMTech in forum mel PIC BASIC Pro
    Last Post: - 19th November 2007, 00:05
  5. How to configure the clock??!!
    By sergio.elias in forum Serial
    Last Post: - 21st June 2006, 05:48
