Maybe I'll ask a broader question. The SI5351 device can generate a number of independent clocks, from a few Hz to over 100 MHz. Sounds pretty useful as a replacement for a VFO in radio projects. I'm pretty sure I can get it going, but the command structure is quite complicated, and I was wondering if anybody had implemented it in PBP yet? I have no problem with I2C or actually talking to the device, I was just hoping to save time on implementing the commands. There is an Arduino sketch for it, but reverse engineering that is probably more work than just starting from scratch. Has anybody taken a poke at this one?
