This is the latest addition to the TEC controller: One pot on ADC1 sets the temperature.
I’ve done it such way so with a linear pot the target temperature can be set between 40 and 65 degrees F.
I think that I will settle for that now. I will just test its performance for the next week or so and wrap the project up for this particular cooler.Code:'Last release 9_16_16 Implements pot for setting set_temp @__config_device_pic16f819 @__config_wdt_off @__config_hs_osc @__config_pwrt_on @__config_mclr_off @__config_lvp_off @__config_protect_on DEFINE OSC 8 DEFINE DEBUG_REG PORTB DEFINE DEBUGIN_REG PORTB DEFINE DEBUG_BIT 6 DEFINE DEBUGIN_BIT 7 DEFINE DEBUG_MODE 1 DEFINE DEBUG_BAUD 38400 DEFINE ADC_BITS 8 DEFINE ADC_CLOCK 3 DEFINE ADC_SAMPLEUS 50 ADCON1=%01001110 pwm_out var PORTB.2 adval var word val_1 var byte val_2 var byte val_3 var byte new var word act_temp var byte set_temp var byte new_temp var byte temp_index var byte i var word pwm_pars var word id var byte pwm_flag var bit start_ch con 126 end_sym con 251 samples con 39 divider con 20 hysteresis con 1 min_pwm con 30 max_pwm con 50 full_pwm con 40 CCP1CON = %00001100 PR2 = 15 CCPR1L = 0 CCP1CON.5 = 0 CCP1CON.4 =0 High pwm_out Pause 500 Low pwm_out T2CON.2 = 1 ' set_temp=69 id="1" pwm_flag=0 goto main send_out: debug start_ch,id,val_1,val_2,val_3,end_sym return set_pwm_pars: CCPR1L = pwm_pars >> 2 CCP1CON=$0C|((pwm_pars&$3)<<4) return read_act_temp: new = 0 For temp_index = 1 TO samples ADCIN 0,adval new = new + adval Next act_temp=new/divider return read_set_temp: new = 0 For temp_index = 1 TO 9 ADCIN 1,adval new = new + adval Next set_temp= 40 + new/100 'keeps set_temp between 40 and 65 deg. F return decide: If act_temp < (set_temp-hysteresis) then pwm_pars =0 pwm_flag=1 endif If act_temp > set_temp and pwm_flag =0 then pwm_pars = min_pwm+(act_temp - set_temp) goto jump endif If act_temp > (set_temp + hysteresis) and pwm_flag =1 then pwm_pars = start_pwm pwm_flag=0 endif jump: gosub set_pwm_pars val_1=act_temp val_2=pwm_pars val_3=set_temp Return Main: gosub read_act_temp gosub read_set_temp gosub decide gosub send_out pause 1500 goto Main end
A friend of mine is offering me a huge 125 bottles cooler with refrigeration problems (old Freon compressor type). If this first attempt will prove successful I will spend more time saving the big cooler which is a lot nicer and a lot more expencie than this one.
I manage to get 6 brand new TECs, more powerful than the other ones (7-8 Amps) and I will start experimenting with them and different setups.
It might take a little time but I will keep you posted.
Thank you everyone for the input.
Nick
