TEC controller
Results 1 to 19 of 19
Thread: TEC controller
    Default Re: TEC controller
    This is how I do it for a word sized variable that gives you 10 bits of resolution:
    CCPF = CCPF MIN MAXPWM
    CCPR1L = CCPF >> 2 'UPDATE PWM1 UPPER 8 BITS
    CCP1CON = $0C | ((CCPF & $3) << 4) 'UPDATE PWM1 LOWER 2 BITS
    EN82fn
    Sep 2009
    For CCP1CON bits this is much faster
    CCP1CON.5=CCPF.1
    CCP1CON.4=CCPF.0
    Oct 2012
    Thank you Dave and Pedja089 for your input.
    I will try implementing your suggestions and report back the results. Unfortunately I just started work so it has to wait for a few good hours.
    I was thinking to try something like this subroutine but it was too late last night:
    Set_pwm_pars:
    	CCP1CON.4 = Pwm_pars.0
    	CCP1CON.5 = Pwm_pars.1
    	CCPR1L = Pwm_pars >> 2
    	FOR i = min_pwm to max_pwm
    	Pwm_pars = i
    	GOSUB Set_pwm_pars
    	PAUSE 250
    	NEXT
    	PAUSE 5000
    	GOTO Main
    My goal for now is to get enough steps with about 0.25V between them so the TEC will not complain.
    BTW does anyone know if slow, occasional (every few minutes) 0.25V steps combined with heavy capacitor filtering will affect the TEC?
    Thanks again for your input.
    Nick
    Oct 2012
    Just a quick update: I’ve tried all three suggested methods and they all work as expected.
    I will do some more hardware changes, now that I have a stable test code. I will experiment especially with frequency changes and inductors values. I’m trying to get as much efficiency as possible.
    What is encouraging though is that running the prototype for long time does not generate heat at all. The main power components are cold and the current draw (from the 12V source) swings between 1A and 2.5A.
    I will post the latest working code as soon as I get it cleaned up.
    Nick
    Oct 2012
    This is the working code. It steps up through 21 steps of PWM (from 30 to 50) and then steps down (from 50 to 20). The result is an output voltage between 5.5V and 8.5V (the numbers are rounded up). This is design for testing the flexibility of the system only. Final code will implement a temperature controlling algorithm. BTW I switched to PIC16F819 since this is the PIC I'm going to use for this task.
    Code based on Dave's input (183):
    @__config_device_pic16f819
    @__config_wdt_off
    @__config_hs_osc
    @__config_pwrt_on
    @__config_mclr_off
    @__config_lvp_off
    @__config_protect_on
    @__config_CCP1_RB2
    OSCCON=%01110111
    DEFINE OSC 8
    i           var         word
    pwm_out     var         PORTB.2
    pwm_pars    var         word
    min_pwm     con         30
    max_pwm     con         50
    CCP1CON = %00001100
    PR2 = 15
    CCPR1L = 0
    CCP1CON.5 = 0
    CCP1CON.4 =0
        High pwm_out
        Pause 500
        Low pwm_out
        T2CON.2 = 1
        goto Main
    set_pwm_pars:
         CCPR1L = pwm_pars >> 2
         CCP1CON=$0C|((pwm_pars&$3)<<4)
         for i=min_pwm to max_pwm
         pwm_pars = i
         gosub set_pwm_pars
         pause 250
         next
         for i=max_pwm to min_pwm step -1
         pwm_pars = i
         gosub set_pwm_pars
         pause 250
         next
         Pause 5000
    Goto Main
    With the same main loop I changed the subroutine set_pwm_pars based on Pedja089 input (163):
    set_pwm_pars:
         CCP1CON.5 = pwm_pars.1
         CCP1CON.4 = pwm_pars.0
    Finally my simplified version for the subroutine (187):
    set_pwm_pars:
         CCPR1L = pwm_pars / 4
    The output from all is the same (as expected). Cannot comment on execution speed and for my purposes it doesn’t really matter. I will only set a step, based on the temperature control algorithm, and sit on it for a while. I’m sure that the wine will not mind a few microseconds shifted response.
    The one difference between the three versions is the code space required. The numbers in parentheses are showing that.
    So far I’m happy with my results.
    I will work on the hardware for the next few days and start working on the temperature control algorithm after that.
    Before I start this new task I’m asking all the people in this forum that might have some experience in this field: Am I on the right track? Is there a better way to do it?
    I love its simplicity and the fact that I fully understand how it works but in the same time I hate to find it out that is wrong after I already spent a lot of time on it.
    As always looking forward for input.
    Nick
    The only problem I can see is that you are assuming the other bits in the CCP1CON are always set correctly? For the sacrifice of a few extra instructions I would prefer to have ALL register bits set as in: CCP1CON=$0C|((pwm_pars&$3)<<4)
    EN82fn
    Oct 2012
    Hi Dave,
    You are making a good point. It comes with lock of experience on my side.
    As I said before I have two good qualities: learning extremely slow and, in contrast, forgetting extremely fast.
    At this point I’m not looking to save program space so I guess playing safe will be a good idea.
    Any input on the hardware side?
    Nick
  1. Repeater ID and controller
    Last Post: - 29th March 2012, 23:06
  2. SMS Controller
    Last Post: - 8th September 2006, 15:12
  3. temperature controller
    By PoTeToJB in forum mel PIC BASIC Pro
    Last Post: - 24th April 2006, 20:01
  4. PID CONTROLLER help..
    By tkly36 in forum mel PIC BASIC Pro
    Last Post: - 12th April 2006, 07:19
