GLCD Megademo :)
Results 1 to 8 of 8
    Aug 2003
    Default GLCD Megademo :)
    Hi Guys
    This isn’t in PBP, so off topic, but if you remember the graphics I did with character LCDs,
    I started on a dsPic with 128x64 GLCD a week ago, and did a multi part demo
    Default Re: GLCD Megademo :)
    Art, that's really impressive.
    Are there any links to code? I would like to understand frame buffering techniques.
    Bombay, India
    Very nice. Good frame rates too.
    Great! Very fast indeed! 5* Art.
    How do you rotate 3d objects?
    Aug 2003
    Hi, Thanks
    It’s written for the public, but that’s not a promise yet.
    It does go: user program, library, hardware driver... but it’s still less than a week into the software part.
    Jerson, I want to mux the 8 data lines with a shift register next time, and slow it down to gain 6 pins,
    but I don’t think it will suffer much. Part of the reason the final thing will be different, or configureable.
    Ioannis, To rotate the objects, every pixel in the object has to be rotated on one axis or another.
    Only one axis for 2D rotation. For the cubes, I was able to do that on the character display in PBP
    because the points for the 3D cube were pre-generated on another platform first.
    To draw the cube you only have to rotate it’s 8 points, and draw lines between the rotated points, so it’s not very costly.
    The code to rotate one point in C reads like BASIC. The x,y input data is destroyed, and the x,y value a that end is the rotated value.
    Rotated around a centre point approximation for 128x64 display. rotation is an integer input in degrees 0-359.
    double d2r = 0.0174532925199433; // (PI / 180.0)
    long double theta;
    long double thetab;
    int rotation;
    int xx;
    int yy;
    int xnew;
    int ynew;
    int rx;
    int ry;
    int ox = 64; // screen centre pixel coordinates
    int oy = 32; //
    theta = rotation; // pre calculation
    thetab = 360 - theta;
    thetab = d2r * theta;
    xx = x; yy = y;
    rx = xx - ox; ry = yy - oy;
    xnew = cos(thetab)*rx - sin(thetab)*ry;
    ynew = sin(thetab)*rx + cos(thetab)*ry;
    xnew = xnew + ox; ynew = ynew + oy;
    x = xnew; y = ynew;
    That was the only reason to use a dsPic and C30 for this.
    The display isn’t written in sequential horizontal lines, so everything else in the software is
    bit manipulation which would all be much better done with PBP/asm with a slower micro.
    Aug 2003
    I can’t seem to edit my first post. It was updated enough that I didn’t like the older one up on YouTube, so here’s the new link:
    Aug 2016
    Interesting.
    Appreciate for sharing.
    Aug 2003
    I don’t really know if this one has been done, but tonight I got a third colour by using a second frame buffer,
    and toggling between the two for every frame. The framebuffer for the grey colour also has the black drawn on it,
    so the black colour ends up 100% duty cycle, and the grey, 50%.
  1. Glcd
    By buddhafragt in forum mel PIC BASIC Pro
    Last Post: - 18th August 2009, 18:58
  2. Glcd help
    By santamaria in forum mel PIC BASIC Pro
    Last Post: - 8th February 2009, 10:11
  3. PBP Glcd
    By RICHARD.C in forum mel PIC BASIC Pro
    Last Post: - 13th June 2008, 02:21
  4. Serial GLCD, how?
    By mindthomas in forum General
    Last Post: - 16th April 2008, 15:00
  5. Glcd
    By Sphere in forum General
    Last Post: - 26th August 2006, 17:48
