default config
Code:#CONFIG CONFIG FOSC = INTIO67 CONFIG PLLCFG = OFF CONFIG PRICLKEN = OFF CONFIG FCMEN = OFF CONFIG IESO = OFF CONFIG PWRTEN = OFF CONFIG BOREN = SBORDIS CONFIG BORV = 190 CONFIG WDTEN = ON CONFIG WDTPS = 32768 CONFIG CCP2MX = PORTC1 CONFIG PBADEN = OFF CONFIG CCP3MX = PORTB5 CONFIG HFOFST = ON CONFIG T3CMX = PORTC0 CONFIG P2BMX = PORTB5 CONFIG MCLRE = EXTMCLR CONFIG STVREN = ON CONFIG LVP = OFF CONFIG XINST = OFF CONFIG DEBUG = OFF CONFIG CP0 = OFF CONFIG CP1 = OFF CONFIG CP2 = OFF CONFIG CP3 = OFF CONFIG CPB = OFF CONFIG CPD = OFF CONFIG WRT0 = OFF CONFIG WRT1 = OFF CONFIG WRT2 = OFF CONFIG WRT3 = OFF CONFIG WRTC = OFF CONFIG WRTB = OFF CONFIG WRTD = OFF CONFIG EBTR0 = OFF CONFIG EBTR1 = OFF CONFIG EBTR2 = OFF CONFIG EBTR3 = OFF CONFIG EBTRB = OFF #ENDCONFIG
Default output frequency of HFINTOSC on Reset.
HFINTOSC/16 – (1 MHz)(3)
DEFINE OSC 8
does absolutely nothing but advise the compiler what freq to base timing calculations on
to use ext xtal
Code:#CONFIG CONFIG FOSC = HSHP CONFIG PLLCFG = OFF CONFIG PRICLKEN = OFF CONFIG FCMEN = OFF CONFIG IESO = OFF CONFIG PWRTEN = OFF CONFIG BOREN = SBORDIS CONFIG BORV = 190 CONFIG WDTEN = ON CONFIG WDTPS = 32768 CONFIG CCP2MX = PORTC1 CONFIG PBADEN = OFF CONFIG CCP3MX = PORTB5 CONFIG HFOFST = ON CONFIG T3CMX = PORTC0 CONFIG P2BMX = PORTB5 CONFIG MCLRE = EXTMCLR CONFIG STVREN = ON CONFIG LVP = OFF CONFIG XINST = OFF CONFIG DEBUG = OFF CONFIG CP0 = OFF CONFIG CP1 = OFF CONFIG CP2 = OFF CONFIG CP3 = OFF CONFIG CPB = OFF CONFIG CPD = OFF CONFIG WRT0 = OFF CONFIG WRT1 = OFF CONFIG WRT2 = OFF CONFIG WRT3 = OFF CONFIG WRTC = OFF CONFIG WRTB = OFF CONFIG WRTD = OFF CONFIG EBTR0 = OFF CONFIG EBTR1 = OFF CONFIG EBTR2 = OFF CONFIG EBTR3 = OFF CONFIG EBTRB = OFF #ENDCONFIG
