32 bit data displaying on LCD
Results 1 to 11 of 11
    rlampus's Avatar
    rlampus Guest
    Default I also kneed to know.
    Dear developers
    I 'm developing an operating panel (LCD and keypad included)
    for Teksco USA.
    I have to display decimal 32 bit full range data (up to 4.294.967.295) on LCD and handle 32 bit data from LCD entered by the user.
    Displaying and retrieving LCD is no problem.
    But How can I display 32 bit decimal data to LCD and calculate new 32 bit data from LCD
    Thank you for your help right now
    Randy Lumpus
    Teksco,USA
    Duh... what i don't understand here...
    Quote Originally Posted by rlampus
    More about the calculation?
    blainecf's Avatar
    blainecf Guest
    Default how do i count to 20 without taking my shoes off?
    When I take my shoes off, I can see my toes, so I can count to 20.
    When I count to 5, I only need to see one hand, but to 10, I need to see both hands.
    Therefore, if a word variable is 16 bits, two word variables is 32 bits. That means, if I declare a 2 element word array, I'll have 32 bits. So I'd just need a simple algorithm to refer to the array and treat it like one 32bit variable.
    You could use assembler, or use any of the bit functions (>> << or var.bit) to handle it.
    bcf
    Jan 2006
    Istanbul
    Quote Originally Posted by blainecf
    When I count to 5, I only need to see one hand, but to 10, I need to see both hands....
    bcf
    Hi blainecf,
    I wonder what would you take off if you needed to count to 40?
    Feb 2003
    Quote Originally Posted by sayzer
    Hi blainecf,
    LOL
    I'm still confused how you get beyond 23
    Keith
    www.diyha.co.uk
    www.kat5.tv
    rlampus's Avatar
    rlampus Guest
    Default Could you give an example?
    bcf
    This is very helpful, Thankyou. Could you please give one example of actual pic basic code.
    r lampus
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    As I have said in the past, there has got to be an easier way....but this might get your ball rolling. I worked it assuming you have no WORD variables and only BYTES. (i.e., I assumed you had a 16 bit number composed of two 8 bit variables instead of your 32 bit number composed of two 16 bit words. Expanding the below to DOUBLE WORDS is similar, just a lot more lines.) (Yes, I know we have WORDS in PBP – I am just demonstrating a process). -THIS IS UNTRIED IN ACTUAL CODE BUT WORKS ON PAPER-
    Background
    bit 1 = 1
    bit 2 = 2
    bit 3 = 4
    bit 4 = 8
    bit 5 = 16
    bit 6 = 32
    bit 7 = 64
    bit 8 = 128
    bit 9 = 256
    bit 10 = 512
    bit 11 = 1024
    bit 12 = 2048
    bit 13 = 4096
    bit 14 = 8192
    bit 15 = 16384
    bit 16 = 32768
    ' Example: Dig 12345 (assuming WORDS not available)
    HiByte VAR BYTE
    LoByte VAR BYTE
    Digit VAR byte[5]
    HiByte = $30	' high byte of 12345 ($30 = 00110000)
    LoByte = $39 ' low byte of 12345
    Digit[0] = LoByte Dig 0	' = 7
    Digit[1] = LoByte Dig 1	' = 5
    Digit[2] = LoByte Dig 2	' = 0
    Digit[3] =  0	' no need to dig because byte 3 decimal places max
    Digit[4] =  0	' no need to dig because byte 3 decimal places max
    If HiByte.0 = 1 then
    	Digit[0] = Digit[0] +6
    	Digit[1] = Digit[1] +5
    	Digit[2] = Digit[2] +2
    If HiByte.1 = 1 then
    	Digit[0] = Digit[0] +2
    	Digit[1] = Digit[1] +1
    	Digit[2] = Digit[2] +5
    If HiByte.2 = 1 then
    	Digit[0] = Digit[0] +4
    	Digit[1] = Digit[1] +2
    	Digit[3] = Digit[3] +1
    If HiByte.3 = 1 then
    	Digit[0] = Digit[0] +8
    	Digit[1] = Digit[1] +4
    	Digit[3] = Digit[3] +2
    If HiByte.4 = 1 then
    	Digit[0] = Digit[0] +6	'=13
    	Digit[1] = Digit[1] +9	'=14
    	Digit[3] = Digit[3] +4	'=4
    If HiByte.5 = 1 then
    	Digit[0] = Digit[0] +2	'=15
    	Digit[1] = Digit[1] +9	'=23
    	Digit[2] = Digit[2] +1	'=1
    	Digit[3] = Digit[3] +8	'=12
    If HiByte.6 = 1 then
    	Digit[1] = Digit[1] +8
    	Digit[2] = Digit[2] +3
    	Digit[3] = Digit[3] +6
    	Digit[4] = Digit[4] +1
    If HiByte.7 = 1 then
    	Digit[1] = Digit[1] +6
    	Digit[2] = Digit[2] +7
    	Digit[4] = Digit[4] +3
    Digit[1] = Digit[1] + Digit[0] Dig 1		'=24
    Digit[0] = Digit[0] Dig 0			'=5  DIGIT0
    Digit[2] = Digit[2] + Digit[1] Dig 1		'=3
    Digit[1] = Digit[1] Dig 0			'=4  DIGIT1
    Digit[3] = Digit[3] + Digit[2] Dig 1		'=12
    Digit[2] = Digit[2] Dig 0			'=3  DIGIT2
    Digit[4] = Digit[4] + Digit[3] Dig 1		'=1 DIGIT4
    Digit[3] = Digit[3] Dig 0			'=2  DIGIT3
    Good Luck
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    rlampus's Avatar
    rlampus Guest
    Default Thankyou.
    Quote Originally Posted by paul borgmeier
    Background
    bit 1 = 1
    bit 2 = 2
    bit 3 = 4
    bit 4 = 8
    bit 5 = 16
    bit 6 = 32
    bit 7 = 64
    bit 8 = 128
    bit 9 = 256
    bit 10 = 512
    bit 11 = 1024
    bit 12 = 2048
    bit 13 = 4096
    bit 14 = 8192
    bit 15 = 16384
    bit 16 = 32768
    HiByte VAR BYTE
    LoByte VAR BYTE
    Digit VAR byte[5]
    Good Luck
    Thankyou. This is very helpful.
    R Lampus
    You might also want to take a look at this thread http://www.picbasic.co.uk/forum/showthread.php?t=1942
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Wink Lucky
    I can only count to 10, toes are too far to count, belly too big to reach!
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Nokia 3310 display text
    Last Post: - 26th August 2007, 04:39
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
