Thanks Henrik, now it makes sense. When I got it to operate correctly under the internal oscillator, by setting the correct values for the OSCCON register, telling it to use the 8 mhz internal clock, it works because software changed the clock source, and not from setting the configuration files which the bootloader ignores to make sure that the configuration needed for the bootloader never changes.
Thanks again
Alec
